Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Reload this Page
One last ditch effort to fix my '01 EX, any help is appreciated! FIXED!!!!
LinkBack Thread Tools
Old 08-27-2008   #16 (permalink)
DannyK35
I'm bigger than you.
DannyK35's Avatar
Location: LINCOLN PARK, CHICAGO, Illinois / Kirkland, WA
DannyK35 is a glorious beacon of lightDannyK35 is a glorious beacon of lightDannyK35 is a glorious beacon of lightDannyK35 is a glorious beacon of lightDannyK35 is a glorious beacon of lightDannyK35 is a glorious beacon of light
Re: One last ditch effort to fix my '01 EX, any help is appreciated!
Alright, got a shop here in Chicago to do the magnaflow cat for $210 out the door on Friday. One less variable to deal with. Thanks again guys.
DannyK35 is offline   Reply With Quote
Old 08-27-2008   #17 (permalink)
2002civicLX2002
The only Wyoming Redneck on here
2002civicLX2002's Avatar
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
a plugged cat WILL cause the engine to miss. im betting thats your only problem, even though there is only one code for it.
2002civicLX2002 is offline   Reply With Quote
Old 08-27-2008   #18 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
keep us updated man
greeen01civic4d is online now   Reply With Quote
Old 08-28-2008   #19 (permalink)
DannyK35
DannyK35's Avatar
VICTORY.
(well, at least for now)
Just got the car back from the shop. Turns out that I also needed to get a new valve cover gasket to replace the old one, it was slowly leaking oil.
I got it back about 1.5 hours ago and god damn the difference was noticeable immediately! Not that these cars are fast/quick but holy shit it was like I was driving a completely different car than I have been for the past few months!
Here is what I had replaced today:
- timing belt/tensioner (OEM)
- water pump (OEM)
- magnaflow catalytic converter
- valve cover gasket
Total cost w/labor and tax: $630. Found a Honda tech online that does side work on his days off, that's a pretty solid deal.
So I'm pretty stoked and not freaking the fuck out about this 2000 mile trip I am taking on Sunday, I just wish I figured that out earlier. And I'll throw the FP60 from lubecontrol.com when it comes tomorrow just for the hell of it.
I want to thank everyone here on 7thGen (I mean civicforums.com) for their input and suggestions, you have no idea how appreciative I am.
Thanks Everyone, and I will update this thread if anything pops up (hopefully it won't).
Old 08-28-2008   #20 (permalink)
2002civicLX2002
I had a suspicion is was a plugged cat since it was missing on all 4 cylinders. thanks for the update and good luck and safe trip.
Old 08-28-2008   #21 (permalink)
greeen01civic4d
balls in ur mouth
Re: One last ditch effort to fix my '01 EX, any help is appreciated! FIXED!!!!
congrats man
Old 08-30-2008   #22 (permalink)
DannyK35
DannyK35's Avatar
Re: One last ditch effort to fix my '01 EX, any help is appreciated! FIXED???
Well, I spoke too soon.
I have been driving it on the highway to test everything out and low and behold, CEL comes on while I'm doing 40 down the street. Ran it over to autozone, only code that popped up (2 times, mind you):
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
So, I'm going to have to guess that it's a faulty oxygen sensor for now. All of the other variables that could cause this are not there (no vacuum leaks, brand new cat, etc).
However, I can tell that my mpg is back up to normal b/c I've got a little over a half tank left and I've put on 180mi from a full tank.
Any suggestions or is it even worth bothering to replace it right now? Leaving tomorrow for Seattle.
Old 08-30-2008   #23 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
prolly replace secondary o2 sensor. it wont affect how the car dirves tho. just do it to turn the engine light off.
gearbox is offline   Reply With Quote
Old 09-05-2008   #24 (permalink)
DannyK35
DannyK35's Avatar
well, just a post script:
Made it to Seattle in less than 2 days, never got the o2 sensor fixed.
However, damn what a difference after the repairs. I averaged 35-38mpg the entire way (best tank was actually 42mpg), doing 85mph and driving through the mountains. Pretty damn good.
Old 09-08-2008   #25 (permalink)
gearbox
Super Moderator
nice glad you made it okay
Old 09-08-2008   #26 (permalink)
greeen01civic4d
balls in ur mouth
u comin back to chicago?? i was in linkoln park the past weekend..
Old 3 Weeks Ago   #27 (permalink)
utahbmxer
Member
utahbmxer's Avatar
utahbmxer is an unknown quantity at this point
Not to Jack a thread. I've been having the same P0300 (random), P0301, P0302, P0303, P0304 misfires as well for the past few weeks. I also had the P1298 (High Voltage in ELD) but I fixed that by replacing the ELD. I can't seem to figure out why I am having all these random misfires. I replaced my plugs, did a fuel pressure test (came out @45psi). I ran Seafoam through tank and throttle body, tried Premium gas this tank. I did pop one P0420 (CAT below thresh) code a few days ago, but it hasn't returned. I am thinking there is some electrical issue, possibly bad ECM. Anyone have any thoughts? I don't want to drop money on a new ECM and have that not be the problem, and I can't find any at the wrecking yards.
-The car shakes bad under say 1,300 RPMs, especially when cold. I can feel and hear it misfire. CEL flashes at this time.
-Doesn't seem to misfire over 1500RPM
-When I drive on the freeway and come to a stop the engine almost dies at like 400 RPMs or below, then slowly creeps back to ~700
-On another note, Car has done a weird idle down when I let off the gas, since I got the car with 62k mi. See video:
YouTube Video
If you are able to see this message it means that you don't have flash installed or that the video server is down.
2001 LX Sedan
5spd
AEM Short CAI
DCSports TCS Exhaust
149,000mi
Thanks,
utahbmxer
utahbmxer is offline   Reply With Quote
Old 3 Weeks Ago   #28 (permalink)
gearbox
Super Moderator
whoa the idle is screwed up bad. try cleaning the whole intake system, throttle body, iac valve, everything. put it all back and relearn the idle. i also think the cat might be going bad (clogged) or maybe the 02 sensor for it also.
Old 3 Weeks Ago   #29 (permalink)
WannaBFast
Prowlin' with a Purpose
WannaBFast's Avatar
the flashing CEL is VERY bad, it basically means you got a misfire that is probablly damaging your cat.. if it already isnt already
might have a clogged cat, or a sensor that is broken
WannaBFast is offline   Reply With Quote
Old 3 Weeks Ago   #30 (permalink)
Krieger
Member
Krieger's Avatar
Krieger is an unknown quantity at this point
Quote:
x2.
thats crazy.
Krieger is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Your answer may be here! TSB / Honda Complaint Address / Etc...
Maintenance required light
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
7th gen civics and their common problems...
Who's had a bad transmission? *UPDATED*
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Timing Belt DIY 2
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
