Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Reload this Page
02 civic DTC-P1457
LinkBack Thread Tools
Old 08-12-2008   #1 (permalink)
j00fek
New Member
j00fek is an unknown quantity at this point
02 civic DTC-P1457
got an evap leak, just found out through a cel and my scanner.
anyone have any experience with this code? and where the evap canister is on the civic?
j00fek is offline   Reply With Quote
Sponsored Links
Old 08-12-2008   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
Re: 02 civic DTC-P1457
could be any number of leaks in the vapor recovery system. the canister is under the car in the rear, by the gas tank. but there are lines going back to engine too that could be damaged. or some of the lines in the engine bay. i know theres one that always rubs if you have aftermarket intake and eats a hole eventually. check that. also try getting a new gas cap, over time the pressure mechanism inside wears out, so does the o-ring seal.
gearbox is offline   Reply With Quote
Old 08-16-2008   #3 (permalink)
02Sicivic
Member
02Sicivic's Avatar
02Sicivic is an unknown quantity at this point
A common fault with those civics is the Bypass control solenoid or canister vent shut valve. P1456 generally is a loose/faulty gas cap.
02Sicivic is offline   Reply With Quote
Old 08-28-2008   #4 (permalink)
j00fek
New Member
finally went under the car yesterday, checked out all the lines to and from the canister. all were fine, checked the gas cap and the o-ring is good to go as well.
im thinkning that one of the solenoid's is gone, does anyone know ho to test those?
thnx
Old 08-28-2008   #5 (permalink)
Albertross
Albertross's Avatar
Albertross is an unknown quantity at this point
Man, I had a terrible problem with that code. Lucky for me it was an easy fix, other people, not so easy.
If you had recently installed an intake, you may have disconnected the EVAP Canister Purge Valve, the one near your IAC sensor. Took me 2 long months just to figure that one out. Code was gone afterwards.
If that's not the case, apparently if you live in an area where winter comes by, the salt from the plowing/salt trucks end up corroding the solenoids and/or the 2-way valve and/or the vent shut valve, causing a blockage of the EVAP system. I don't know if we have a PCM in our cars, but in other cars it would cause it to short out.
In terms of the testing, I'm pretty sure you gotta take it to Honda for that. I know it requires some machine but I forget which one.
Albertross is online now   Reply With Quote
Old 08-29-2008   #6 (permalink)
j00fek
New Member
im thinkning that that the solenoids are not opening as well, i have been listening to the tank when i take the cap off. every time that i take it off there is alot of air coming out of the tank, making me believe that the fumes are not getting to the canister...?
this car is stock as well, no mods
Old 08-29-2008   #7 (permalink)
Albertross
Albertross's Avatar
The fumes come out because the fuel system is under pressure. That's just pressure being released.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Your answer may be here! TSB / Honda Complaint Address / Etc...
Maintenance required light
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
7th gen civics and their common problems...
Who's had a bad transmission? *UPDATED*
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Timing Belt DIY 2
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
