Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Reload this Page
car is overheating!!
LinkBack Thread Tools
Old 07-30-2008   #1 (permalink)
dcjose20
New Member
dcjose20's Avatar
dcjose20 is an unknown quantity at this point
I have an 01 civic coupe ex and there has been three separate incidents in which the car starts to overheat. The last two times that it has happened, as soon as i start going the gauge starts to drop. So im thinking that it might have something to do with the fans. I checked for leaks and didnt find any. I also checked the fuse and it hasnt gone out. I know someone who works for a honda dealership and he said it might be a faulty fan switch but he cant check my car out until next saturday and i kind of want to fix the problem already cause its been going on for over a month know. is there a test i could do at home and how hard would it be to replace it myself. Im not really an expert but with instructions im sure i could get the job done. Or should i just wait til he could look at it?
dcjose20 is offline   Reply With Quote
Sponsored Links
Old 07-30-2008   #2 (permalink)
RallyeRedRider
Member
RallyeRedRider has a little shameless behaviour in the past
Re: car is overheating!!
Does your fan turn on and run when it's over heating?? If so then the fan switch isn't the problem. You said you checked for leaks and the fuse, did you check the coolant level too? If not, a system that wasn't toped off could stay cool under normal driving, when it wasn't being pushed hard, but would probably over heat at a stop. One more question. It seems that this always happens while your stopped. How long do you usually sit before it occurs? Does it always overheat if you sit and idle for that long?
RallyeRedRider is offline   Reply With Quote
Old 07-30-2008   #3 (permalink)
dcjose20
New Member
dcjose20's Avatar
There are times that i hear when the fans are on. yes i checked the coolant level too and it was fine. usually i sit for like 4 mins and then it will start to overheat. It doesnt happen all the time that is why im thinking maybe there is a loose wire or something. Doesnt help out that i live in so cal and the temp is like 85 to 90 everyday that is why i want to fix it so im not always worried about it especially since im going to be going to school everyday and have to travel 30miles each way.
Old 08-04-2008   #4 (permalink)
slamminsalmon
Member
slamminsalmon's Avatar
slamminsalmon is an unknown quantity at this point
im having a very similiar problem. with the same car.
on the hot days my car quickly heats up. the needle gets very close to the red while driving around the city or idling. it started about 2 weeks ago with some of the hot hot weather.
down the highway or interstate it stays at an optimal temp, and even gets lower when i turn the ac on.
i hear my fan turn on also, there are no leaks, and my coolant is topped off. could it use a flush?
to add right around the same time, my car started sounding louder. would a leak somewhere in the exhaust cause the temp to rise?
slamminsalmon is offline   Reply With Quote
Old 08-04-2008   #5 (permalink)
RallyeRedRider
Member
slammin:
An exhaust leak will change the dynamics of the engine, causing it to run lean, or rich, which can cause the engine to create more heat. Reset the ecu, that should help some until you fix the leak, then reset it again.
Of course you still may have a different problem.
EDIT: Where is the exhaust leak? If it's near the header it could be shooting exhaust air right into the radiator.
dc:
I would suggest flushing the system. I'd probably go ahead and replace the thermostat while the coolant was out. It may be occasionally sticking, or only opening partially sometimes, something like that.
Old 08-04-2008   #6 (permalink)
slamminsalmon
Member
im gonna get it on a lift this week to find it. i can hear it more towards the engine. it definitely runs a little funky since too. but noticeably losing fuel mileage.
also, would the leak possibly blow hot air onto the thermostat? or that wut you mean but shooting exhaust into the radiator?
thanks for the advice!
Old 08-05-2008   #7 (permalink)
RallyeRedRider
Member
Quote:
Not quite, I was saying it could be pushing hot exhaust gas through the radiator, instead of cool out side air pulled in by the fan, which wouldn't help to cool the water any.
If the exhaust leak effected the thermostat (which it can't reach) it would cause your car to run cold, not hot, since the thermostat would always be opened.
Old 08-05-2008   #8 (permalink)
slamminsalmon
Member
hmmm that makes a lot of sense! thanks.
Old 08-18-2008   #9 (permalink)
slamminsalmon
Member
so i got it on a lift, after 1 guy trying to charge me 75 bucks to lift it! DOUCHE!
i parked it, waiting for another appointment. took it in last friday, no signs of exhaust damage, anywhere.
he said the newer civics can be really iffy when it comes to which coolant you choose. so he added some coolant directly to the radiator. it was the honda blue coolant. was like 28 bucks a gallon!
but she seems to be running like a dream, the temperature is running lower than ever. i also learned i will always spend the extra money for the honda coolant.
Old 08-18-2008   #10 (permalink)
RallyeRedRider
Member
That's where you were adding it and checking it too right??? Just making sure. Because the overflow tank can have fluid in it when the radiator is low.
Old 08-19-2008   #11 (permalink)
impark
New Member
impark is an unknown quantity at this point
My 2003 civic ex is also overheating also. There has been several incidents where it would start overheating... I replaced the thermostat, and it ran fine for about a week, until it started to overheat again. Each time, I would blast the heat, and drive the car at least 40 mph+. Weird thing is, the car would stop overheating after awhile. I took it to my mechanic and he replaced the thermostat again, saying everything else is working fine. Now its starting to overheat again... weird but the overheating usually happens when it rains...
impark is offline   Reply With Quote
Old 08-19-2008   #12 (permalink)
RallyeRedRider
Member
perhaps you have exposed wires somewhere and the rain is shorting out the fan.
Old 08-19-2008   #13 (permalink)
slamminsalmon
Member
Quote:
originally i wasnt adding any to the radiator. i pretty much learned that from this whole incident
Old 08-19-2008   #14 (permalink)
RallyeRedRider
Member
Well, that's the cure, not the genuine Honda coolant, although I'm sure that at nearly $30 a gallon it's good stuff.
Old 08-29-2008   #15 (permalink)
nateschisler
New Member
nateschisler is an unknown quantity at this point
Re: car is overheating!! GOOD INFO
Guys...I don't post a lot on this forum, but I use it a lot and good some info from my mechanic on this problem that might be useful.
My Story:
About 3 months ago, I noticed my car overheating. When I was running at 45+ on the open road, it ran fine, but would spike anytime I slowed down, get behind somebody, came to a stop, etc. Only did it when the A/C was off - diagnosis - bad radiator fan switch - tested and confirmed bad by my mechanic. Got switch replaced. A month later, starts happening again, exact same symptoms. Take it back to my mechanic and as any good mechanic should, replaces the switch no charge. Starts happening AGAIN! Take it back to my mechanic, looks over the car for like a day, baffled.
In between trip two and three, I was actually driving by his shop and it was overheating, I pulled into his lot, drug him outside, popped the hood and pointed at my cooling fan which was NOT RUNNING as the engine was running near red line. So he's had it for two days now. When he starts it up in the parking lot and lets it idle up to temperature, everything works PERFECT, fans and all. Finally came up with a creative diagnosis that I'm going to confirm myself this weekend (thanks to this fantastic forum and it's many DIYs):
When I drive to and from work, I hop in my car start, and leave - literally no stoplights and only 1 stop sign between my house and work - 20 minute drive. Car heats up very quickly - unlike when he lets it heat up in his parking lot. He believes that my head is warped and/or head gasket is damaged in between one of the cylinders letting exhaust/combustion gas leak into one of the cooling chanels pushing air into the system...once this air pressure makes it to the fan switch, the switch doesn't function. He suspects the warping/damage occured from the initial round of habitual overheating caused by the fan switch ACTUALLY being faulty.
Passes my smell test, what do you guys think?
nateschisler is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Your answer may be here! TSB / Honda Complaint Address / Etc...
Maintenance required light
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
7th gen civics and their common problems...
Who's had a bad transmission? *UPDATED*
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Timing Belt DIY 2
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
