Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Reload this Page
rough idle and no power
LinkBack Thread Tools
Old 08-22-2008   #31 (permalink)
rahenry00
Member
rahenry00 is an unknown quantity at this point
Re: rough idle and no power
OK...it could be a multitude of things so get the code and then we go from there.
rahenry00 is offline   Reply With Quote
Old 08-22-2008   #32 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
on our car, primary upstream is right below the header, secondary downstream is inside the cat. at least for the ex model. lx has the cat builtin to the header, so the two sensors are much closer together, but same placement applies. make sure you use oem type sensors (bosch/ntk) with the SAME length wiring and plug.
gearbox is offline   Reply With Quote
Old 08-22-2008   #33 (permalink)
jj_diamond
Member
jj_diamond is an unknown quantity at this point
but in some cases like mine, the header has a different placement for the primary sensor. therefore you have to use an extension.
jj_diamond is offline   Reply With Quote
Old 08-22-2008   #34 (permalink)
Albertross
Albertross's Avatar
Albertross is an unknown quantity at this point
Quote:
Yeah, no point in guessing the problem unless you know the code that the ECU is throwing at you. Get an OBDII reader or have someone check it out (lots of shops have it, even some quick lube shops). Diagnose the code then you can diagnose the problem.
Albertross is online now   Reply With Quote
Old 08-24-2008   #35 (permalink)
jj_diamond
Member
code P1362 manufacturer control. ignition system or misfire.
it only really happends when it's really hot and the a/c is on.
Old 08-25-2008   #36 (permalink)
rahenry00
Member
Get some new NGK plugs
Old 08-25-2008   #37 (permalink)
jj_diamond
Member
i put fresh NGK's in it 5 months ago.
Old 08-25-2008   #38 (permalink)
rahenry00
Member
Maybe the coil packs are dead. I am not if there is a test for your packs but hopefully they're ok, they are expensive. Did you torque the plugs to the correct spec?
Old 08-25-2008   #39 (permalink)
jj_diamond
Member
yes. it runs fine until the CEL comes on. and like i said it only happens when it's really hot and i run the a/c for a bit. the engine seems to be really hot when you open the hood. the temp gauge reads fine and is working.
could it be a bad PCV valve?
Old 08-25-2008   #40 (permalink)
Albertross
Albertross's Avatar
P1362 TDC Sensor No Signal - Taken from the OBDII codes sticky.
First thing to check is the TDC sensor in the distributor. Apparently, heat from the distributor + moisture from the high-running A/C = potential shorts within the coils or electrical components of the distributor. Try not to run the A/C on full blast so much.
Or you can replace the whole distributor and go from there.
Old 08-25-2008   #41 (permalink)
jj_diamond
Member
funny thing is, when i do run the a/c i only run it on half not fully cranked. because i'm aware of the CEL problem.
maybe the extreme heat from the bad catalytic messed up the TDC sensor? i'm assuming like any other sensor these can go bad due to extremeties? easliy replacable?
Old 08-25-2008   #42 (permalink)
ugabuga
New Member
ugabuga's Avatar
ugabuga is an unknown quantity at this point
i didnt know we have a distributor. I dont see one in MY car.
ugabuga is offline   Reply With Quote
Old 08-25-2008   #43 (permalink)
jj_diamond
Member
Top Dead Center SENSOR Replacement.
10 is the TDC sensor
Old 08-25-2008   #44 (permalink)
rahenry00
Member
We don't have one.
Old 08-25-2008   #45 (permalink)
jj_diamond
Member
after looking at the area on the engine i'm assuming the rubber grommet on the side of the timing cover is the TDC sensor plug/wire? does the valve cover really need to come off?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Your answer may be here! TSB / Honda Complaint Address / Etc...
Maintenance required light
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
7th gen civics and their common problems...
Who's had a bad transmission? *UPDATED*
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Timing Belt DIY 2
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
