Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-28-2009   #76 (permalink)
Enzochi
New Member
Enzochi is an unknown quantity at this point
Re: Timing Belt DIY 2
Quote:
Originally Posted by MarkM01 View Post
You probably had it right the first time.
Do you have a repair manual? Sometimes when you disconnect the battery for long periods of time, and go to start it, it'll run like crap. You have to do a restart mode, the manual states how to do it. You basically run it at a certian rpm, like 2000, until the fans kick on, and then let it idel, etc. I don't know the exact procedure, but I'd bet that's what you need to do.
I've worked on my car many times, and it's only done this to me once. I just had to run it awhile, and it was back to normal.
Hello,
I just finished my timing belt today. Needless to say, when I start the car it idles really rough. The engine won't shut off either. It will just run. It seems like the idle is a bit low as well. I'm 99.99999% sure that I had all the timing marks line up properly and that the motor was at TDC. And all the belts are properly tensioned. I also had the battery out over night. Before I go out and hold the accelerator down and blow up the motor. Is there anyone that confirm the 'motor reset'? I've looked in my O-manual and the Haynes Manual and I can't find anything like this.
Any help would be great!
Also, I can confirm that the ABS system is a complete pain in the ass when doing the t-belt.
Thanks,
Adam Kress
akress.com
enzochi@gmail com
Enzochi is offline   Reply With Quote
Sponsored Links
Old 06-29-2009   #77 (permalink)
MarkM01
Member
MarkM01 is an unknown quantity at this point
Quote:
Originally Posted by Enzochi View Post
Hello,
Thanks,
Adam Kress
akress.com
enzochi@gmail com
The engine wont shut off? When you turn the key off, it keeps running?
It the Haynes manual, look at section 5-2, it's the PCM idle learn procedure.
If you can't fine it, let me know.
What problems did you have with the ABS system?
MarkM01 is offline   Reply With Quote
Old 06-29-2009   #78 (permalink)
MarkM01
Member
Here you go.
Perform the ECM/PCM idle learn procedure, as follows:
Make sure all electrical items (A/C, audio, rear defogger, lights, etc.) are off.
Start the engine, and hold it at 3,000 rpm without load (in Park or neutral) until the radiator fan comes on, or until the engine coolant temperature reaches 194 ºF (90 ºC).
Let the engine idle for about 5 minutes with the throttle fully closed.
Old 06-29-2009   #79 (permalink)
jackburton
Diamond Member
jackburton will become famous soon enough jackburton will become famous soon enough
abs bracket gets in the way of motor mount bracket. Its also in the way for some other stuff... Not so much that it makes anything impossible though.
__________________
Have you paid your dues jack?
The check is in the mail
jackburton is offline   Reply With Quote
Old 06-29-2009   #80 (permalink)
Enzochi
New Member
Thanks for the reply's. I will re-check the haynes manual tonight when I get home. I've been told by a few people that it is off by one tooth. This morning I held the engine at 2000 RPM. At 2K the motor did sound a bit unhealthy. That is why I would think that it's a tooth off. I didn't push it past 2K though and the 'Check Engine' light came on too. Also, when I had it apart and I turned the motor by hand it turned over easily by hand. I didn't have to force it. So I know the valves aren't hitting.
Oh, and it will shut off when I turn the key off. The engine won't stall when running...
here is a pic of the new belt installed ->
http://www.flickr.com/photos/enzochi/3669648263/
also, the ABS system is just in the way.. it's a PITA. And to add some fuel to the fire. My stereo now has an ERR2 on the screen. I'm not sure what that means yet.
Old 06-30-2009   #81 (permalink)
Enzochi
New Member
Well, I tried the reset. It didn't work. I took the car back apart an I'm going to recheck everything tomorrow evening.
Thanks for the help so far!
Old 06-30-2009   #82 (permalink)
jackburton
Diamond Member
Did you move either the crank or cam pulley after taking the belt off?
When I took mine off I did not have to move either, because it was already at TDC. The belt never slipped a tooth. When I put the new one on it just slipped right on perfectly.
It sounds like you are going to have to pull a spark plug and be very very careful and take your time. ( I know that really doesn't help)
__________________
Old 06-30-2009   #83 (permalink)
MarkM01
Member
Yeah, mine came off and then sliped right back on like jackburton.
I took a straight edge and layed it accross the cam pully to try and line up the marks level with the head. But it's still kinda just eye balled.
Good luck, you'll get it.
Old 06-30-2009   #84 (permalink)
Enzochi
New Member
I think the crank pully moved a bit. I'm going to get out the laser lever to check the cam later today. And try the straw down the spark plug tube to make damn sure that it's at TDC. I have some pictures here ->
http://www.flickr.com/photos/enzochi/3675451976/
The only real mistake I made so far is not marking the old belt before I took it off. I'm just not 100% sure on how much tension to put on the belt between the crank and cam pully. And that is where I think it's off a tooth. It seems like there is too much slack there.
Old 06-30-2009   #85 (permalink)
Enzochi
New Member
Just got the motor back together. It was off by one tooth. I moved it one tooth counter clockwise on the cam pulley. The problem I was (I think) having was when I put the spring from the tensioner back on the post it was knocking the crank pulley out of TDC. So I marked the teeth on the cam with a marker, unsprung the tensioner, moved the belt, then put the spring back into place. Everything lined up perfectly. I turned it over by hand a couple of times and both cam and crank stayed in the correct spots. Buttoned it back and started it. It sounds good so far. I haven't put the wheel back on yet. I will tomorrow and test.
Thanks again!
Adam Kress
akress.com
enzochi@gmail com
Old 07-20-2009   #86 (permalink)
pheaton
A descendent of 2k1civic.com
pheaton's Avatar
pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light
Send a message via AIM to pheaton Send a message via MSN to pheaton Send a message via Yahoo to pheaton
I'm getting ready to tackle this baby this weekend. I'm going to opt out on the coolant flush and oil change, because I've just had that stuff done recently. I have 105k on the car, so it's time to stop putting this off. One of 3 belts is starting to squeek. The belt that is easiest to see is noticeably cracked and worn, so I can imagine the others are in similar shape.
I got the Crank Pulley Holder tool and some beefy sockets, extensions, and breaker bar and cheater pipe to get that bolt off.
I'll let everyone know how this went after I'm finished.
Just a couple of suggestions as I'm reading up on this prior to tackling it. Socket/bolt sizes would be great. I can't confirm, but I think the crank bolt is 18MM? Anyone? Just so a person can verify that he has the right stuff.
Also for tools, you may want to mention the belt tension gauge, and any various lubricants, or cleaners that you might have used.
Lastly, on the step 38 idiot check, you might want to put that grenade pin in there. To help remind a person to take that sucker out.
All in all, this DIY has given me confidence to be willing to even attempt this, so great job. I am changing the water pump, valve cover gasket, tensioner and the 2 other belts since I'll be in there. I'm setting aside the entire weekend for this, just in case it turns into a fiasco. Wish me luck!
__________________
- Stay in front, that way you don't have to worry about passing anyone.
pheaton is offline   Reply With Quote
Old 07-20-2009   #87 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
crank pulley bolt is a 19mm, and brake cleaner and water are good cleaners, so is simple green
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 07-23-2009   #88 (permalink)
JBS36606
New Member
JBS36606 is an unknown quantity at this point
I have two questions.
1. I would like to make sure my timing is correct (by cranking) before putting the alternator and PSP back. Are there any issues with this approach?
2. Do I need to move the ABS system or work around it? It seems to be in the way.
Thanks for the response in advance.
JBS36606 is offline   Reply With Quote
Old 08-16-2009   #89 (permalink)
jvolpert
New Member
jvolpert is an unknown quantity at this point
Hi I just changed my timing belt. The car is shaking a little at idle but has power at higher rpms. Any ideas on the problem? I'm not sure if I should let the computer "learn" some more or if I should tear into it again to make sure the marks are still lined up. The check engine light is blinking also. Thanks for any suggestions.
jvolpert is offline   Reply With Quote
Old 08-16-2009   #90 (permalink)
jvolpert
New Member
Quote:
Update I just checked and the marks are lined up.
Tags
04145plc315 , 2001 , 2003 , belt , bolt , civic , crankshaft , diy , gauge , honda , mechanical , physics , rotation , tension , timing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
