Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-19-2007   #1 (permalink)
draganjr
Senior Member
draganjr's Avatar
draganjr is an unknown quantity at this point
Crank Shaft Pulley Question
I am installing a new timing belt.
I have a 2002 EX. What are the notches on the crank shaft pulley? The cam shaft is in TDC for 4. Can I make the crank shaft TDC with 4?
thank you.
__________________
Heatware
PayPal Verf.
draganjr is offline   Reply With Quote
Sponsored Links
Old 11-19-2007   #2 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Re: Crank Shaft Pulley Question
White notch on crankshaft is TDC for #1 (piston closest to the crank).
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 11-19-2007   #3 (permalink)
draganjr
Senior Member
draganjr's Avatar
There are no colors on the pulley. I know which one is the TDC for 1 but is one of the notches for TDC for 4?
__________________
Heatware
PayPal Verf.
Old 11-19-2007   #4 (permalink)
speedfoos
speedfoos's Avatar
No there are no notches for any of the other TDC points. But here, I was typing this on one of your other posts.
Dude. Stop. Did you pull the head? The reason you can't turn the cam is because the valves are hitting the pistons. You need to pull the head off again, put the cam to TDC, then put the crank to TDC. Pull the timing covers and crank pulley back off and straighten out the mess you just made of the timing belt.
How did you end up in this situation??
__________________
www.7thgenhonda.com
Old 11-19-2007   #5 (permalink)
draganjr
Senior Member
draganjr's Avatar
We can stick to this post.
I wrote this in the other one.
I did not pull the head? I followed the Helms and then it came to a time to TDC the cam and crank. the crank is at TDC but the cam is at TDC for 4. The "UP" is down.
Do I need to pull the head to fix it?
I lined up the crank pulley with the TDC to the arrow (belt still on) and removed the bolt. the line and arrow still lined up. Removed bolt and cont with uninstall. Removed belt etc...
Installing the belt I lined up the timing belt pulley with the line on the pulley to the line on the block. (no timing belt on yet) (didnt really need to move it already lined up). but the cam is in TDC for 4 "UP" is down.
__________________
Heatware
PayPal Verf.
Old 11-19-2007   #6 (permalink)
draganjr
Senior Member
draganjr's Avatar
Any one?
__________________
Heatware
PayPal Verf.
Old 12-02-2007   #7 (permalink)
matthewinaz
New Member
matthewinaz is an unknown quantity at this point
$420.00 lesson learned
See if that helps you out..The link above. I haven't done mine yet but am going to put cylinder 1 at TDC- This is the cylinder closest to the timing belt. The pully should say up on it. I would pull the valve cover. I know the oil pump has a mark on it so line that up with the other line. As far as the crank shaft...darn..i don't have my manual on me right now...I'll have to get back to you..
matthewinaz is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
