Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-23-2007   #1 (permalink)
fyrfytrryn
New Member
fyrfytrryn's Avatar
fyrfytrryn is an unknown quantity at this point
timing belt help...
well the 03 is about to click 109,000... time for the timing belt gig i suppose.
through looking in my manual (haynes) and browsing the civic forums, ive got a few questions.
1. TDC, do i just have to line the marks up, or does it HAVE TO be #1 piston TDC?
2. i dont own a ft. lb torque wrench or an in. lb torque wrench, will i need them? i also dont own a powerful impact, and im afraid i will shear the head off the crankshaft bolt with force rather than impact. at this point, i will just sell this thing.
3. with all the parts coming from autozone, parts alone come up to 280.00, thats minus any kind of tool (like the one i need to hold the crankshaft pulley, a torque wrench if need be). im not sure how much all the parts would be from honda (today is sunday, parts is closed) and i would really like it to stay genuine honda, should i just pay them to do it? they want like 430.00 OTD, and i dont want to mess it up. ive done the TB on my ranger, but that was CAKE, i didnt really have to remove 20 things before even seeing the belt.
on top of all this, the only time i will have to do this is a sunday after 10:00, other six days are full, and monday i have to be up @ 6:00.
based on this, how many of you suggest i take this sucker to be done and not have to rush it on a sunday? im pretty mechanically inclined, but id hate for something to go wrong and not have the car drivable. thoughts? thanks in advance guys!
__________________
panic can save your life, provided you are the first to panic and you are headed in the right direction.
fyrfytrryn is offline   Reply With Quote
Sponsored Links
Old 09-24-2007   #2 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Re: timing belt help...
1. I've done them with whichever piston happens to be at TDC, not necessarily #1.
2. You absolutely must have a torque wrench. No gettin' around this one really. You have to torque the crank pulley back on properly, if not it could fall off and you will fubar your car.
3. You can borrow a torque wrench from Autozone, but you will need the Honda crank pulley holder. Again, no (that I know of) gettin' around this one.
4. What are OTDs?
5. If you're movin' and groovin' this job "should" take about 4 hours.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 09-24-2007   #3 (permalink)
flotsamm
Ultimate Member
flotsamm's Avatar
flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold
OTD is Out The Door
__________________
Hold On Not Done Accelerating!
flotsamm is offline   Reply With Quote
Old 09-24-2007   #4 (permalink)
speedfoos
speedfoos's Avatar
Ah. I thought it was something like Ontario Dollars. You never can tell with those nutty Canadians.
__________________
www.7thgenhonda.com
Old 09-26-2007   #5 (permalink)
02civic21
Ricky Bobby style, IWGF
02civic21's Avatar
02civic21 is a jewel in the rough 02civic21 is a jewel in the rough 02civic21 is a jewel in the rough
Send a message via AIM to 02civic21
i agree with foos here but 280 bucks damn all you shoud need is the manual, torque wrench, the belt and a few different size wrenches maybe a stubby phillips head because you have to take off the covers. oh and that tool to hold the crank (if you dont use the impact) or you could use a hammer bar. its a pretty easy job except for the crank bolt. i had to hire a mobile mechanic to do mine and he had to call a buddy of his with an air compressor on the back of his truck so he could get that thing off. 19mm socket for the crank bolt and 10mm to remove the covers. then turn the cam until the valves are at a neutral position(all valves closed or partially open) so the pistons can move without hitting the valves. then turn the crank until it lines up with the mark on the block. once that is done turn the cam so that the "up" is up on the sprocket. now the crank and the cam are at TDC so you just use the phillips head to loosen the tensioner and slip the belt on. then put it all back together. just torque that crank bolt down
sorry for the thread jack i get carried away sometimes
__________________
Quote:
Originally Posted by speedfoos View Post
Did someone come by and steal most of the vowels off your keyboard?!
Quote:
Originally Posted by filipinop1405 View Post
Get me a juice box!
1HGEM2
Quote:
You're trying to build a motor without being "so technical"? Get the hell out of here. What do you think it is, legos?
<!-- show-my-ip.com IP box code v.1.0 -->
<script language="javascript" src="http://show-my-ip.com/box/create"></script>
02civic21 is offline   Reply With Quote
Old 09-26-2007   #6 (permalink)
speedfoos
speedfoos's Avatar
Quote:
Originally Posted by 02civic21 View Post
then turn the cam until the valves are at a neutral position(all valves closed or partially open) so the pistons can move without hitting the valves. then turn the crank until it lines up with the mark on the block. once that is done turn the cam so that the "up" is up on the sprocket. now the crank and the cam are at TDC so you just use the phillips head to loosen the tensioner and slip the belt on. then put it all back together. just torque that crank bolt down sorry for the thread jack i get carried away sometimes
This seems really complicated. Why not just set the crank at the white TDC mark with the timing belt still on, pull the cam sprocket off - head now stays at TDC, then remove the crank pulley. This way you're not independently rotating the cam and the crank to set them to TDC. You also don't have to mess with the tensioner at all. I don't know.
After thinking about it, I guess it's six of one half dozen of the other....still thinking.........it may be better going your route as that way you are guaranteed to get the ribs on the belt and the cogs lined up right, instead of eyeballing a new belt on to the cam gear and reattaching it the the cam.
__________________
www.7thgenhonda.com
Old 09-26-2007   #7 (permalink)
02civic21
02civic21's Avatar
well you have to remove the belt to take off the cam and then to put it back on you must mess with the tensioner. because the belt is really tight
__________________
Get me a juice box!
1HGEM2
Old 09-26-2007   #8 (permalink)
speedfoos
speedfoos's Avatar
Hmm. When I did mine on Monday I just removed the cam gear bolt and slipped the whole gear off with the belt. I did the same thing when putting it back on last night. Put the belt on the right teeth of the cam gear and then slipped the whole thing back onto the end of the cam and put the bolt back in.
Oh well. Two different ways to accomplish the same thing.
__________________
www.7thgenhonda.com
Old 09-26-2007   #9 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
god, i need to do this too, but im kinda scared, dont really want to take it on, but i need to
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 09-27-2007   #10 (permalink)
speedfoos
speedfoos's Avatar
Aren't you a mechanic Adam?! Grow a pair and dive in brother! It's actually really easy and a lot less to worry about than if you were jerking the head off the motor.
__________________
www.7thgenhonda.com
Old 09-27-2007   #11 (permalink)
MarkM01
Member
MarkM01 is an unknown quantity at this point
$430 for the dealer to do it? LOL. Why consider the hassle and time to do it yourself? No offense, but it sounds like it's to much of a job for you to do.
MarkM01 is offline   Reply With Quote
Old 09-27-2007   #12 (permalink)
02civic21
02civic21's Avatar
hey that mobile mechanic i mentiond earlier he only charged me 150 to do it all for me
__________________
Get me a juice box!
1HGEM2
Old 09-27-2007   #13 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
TDC #1 because when you do, it puts the key that holds the pulley on the crank on top, which increases the likelihood of it staying put when you take the pulley off. Its a little tiny thing which is a pain in the ass to find if it falls.
You also should TDC #1 because the stock cam gear really only has timing marks for #1. I guess you could try and TDC #3, but its so easy to do 1 that it makes sense.
You dont really need a torque wrench. The spec on the pulley bolt is 14.5 lb-ft plus 90 degrees. This equates to the very accurate spec of "Really Fuckin Tight".
I dont know why parts are so much. The belt is $12, the water pump is around $70. If you need a tensioner, the tensioner set is about 70 and new accessory belts are 8 and 11 respectively. If you're buying from the dealer, you're getting ripped off. Buy them through majestic honda's online parts dept. DO NOT impact gun the crank pulley bolt. Get the pulley tool, a 1/2" drive 19mm socket and a 5' breaker bar, take the bumper off and lean on it. They're not too bad with leverage and the proper tools.
Its a pain in the ass because there's no room. If you have to do it overnight, I wouldnt.... you got about 2.5" to work with in there, and if you dont know what you're doing, I'd do it in daylight.
$430 doesnt sound too bad for a T-belt and H2O pump job.
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Old 09-27-2007   #14 (permalink)
02civic21
02civic21's Avatar
why can t you use impact on crank bolt?
__________________
Get me a juice box!
1HGEM2
Old 09-27-2007   #15 (permalink)
Boilermaker1
Jap-Euro Fusion
1. Because the manual says not to.
2. Just think about it.... motor off, no oil pressure, do you really want to slam that thing around with a 1000 lb-ft air gun? Or just lean on it with a breaker bar and slowly pop it loose.
3. You can also snap the snout off the crank with an air gun... which is obviously bad.
4. you dont want to shock load the crankshaft.
__________________
2002 Civic
Tags
belt , damage , timing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
