Mechanical Problems/Vehicle Issues and Fix-it ForumIf you've got a problem you just can't figure out, a noise you can't diagnose, or a Check Engine Light that won't go away, ask about it here!
Welcome to civicforums.com!
Welcome to civicforums.com.
Okay I have tried universal grease ,I've tried Lithium grease, and still sqeaks i am starting to run out of ideas here i took it to the honda dealership once for them to do it it worked for about a month than started again . i know for sure its the clutch pedal assembly NOT the clutch master cylinder.
If anyone has a quick fix for this problem, could you let me know a.s.a.p.
__________________
Sponsored Links
Follow the pedal assembly through the fire wall.. shoot it with white lithium greese from both sides, and really get it in there. Then find the double boot and spray the heck outta the inner boot too. No more squeeks.
yea i have already loaded lithium grease on the slave cylinder and the release fork and no more sqeaks coming from there it the damn pedal ill try the PB blaster that always comes in handy.
WD40 all the way ... u will need to do it again after 4 months though !!!
Keep in mind when ur spraying the WD40 with your other hand keeping pressing and releasing the clutch at the same time and ull notice all the squeaks go away ...
