how to change 2001 civic automatic transmission fluid?
Old 03-12-2007
DoubleBogus's Avatar
DoubleBogus is an unknown quantity at this point
Is there a drain plug for the 2001 honda civic's automatic transmission and where?
Old 03-12-2007
Runumhard Or Go Home
bigainabuilt's Avatar
bigainabuilt is an unknown quantity at this point
If I told ya there would be no reason for the "Search" feature. Yes there is one located on the passenger side of the transmission. Welcome to the forums and please search.
Old 03-12-2007
found it on search, under drain bolt : p Some of the links are outdated but a diagram listing the bolts is toward the bottom of the posts for this link.
https://www.civicforums.com/forums/7...tf-change.html
Old 03-12-2007
RHCP0801's Avatar
yea there is a drain plug on the passenger side of the tranny pan and you need a 3/8th inch ratchet with no socket on it to take it out, than let it all drain out, clean off the end of the plug and fill it back up with about 3 quarts of honda atf, i just did mine yesterday
Old 03-12-2007
Sweet! I love the search feature.
mattdoc
03-14-2017 12:10 PM
bsmiley
04-27-2015 01:27 PM
alexkharden
04-23-2015 07:13 PM
liljoe
11-04-2001 01:27 PM
HitlistCivic01
10-27-2001 07:47 PM
Quick Reply: how to change 2001 civic automatic transmission fluid?
