Turn Signals Died
Old 11-10-2006
MarkieMark's Avatar
MarkieMark will become famous soon enough
Turn Signals Died
Went to go pick up my friend yesterday from work. My signals were working
fine the whole way. But on the freeway going home my signals died. So we went
to Q-Cup(local pearl drink place) and checked it out. With my headlights on I can
still see the signal light bulbs on also. So it can't be the bulb.
I checked the turn signal fuses and hazard light fuses and nothing was wrong.
I even changed them just to make sure.
What else should I do? Feels different w/o signals. I use them about half the
time I drive and that's when I need to.
Old 11-10-2006
CraigW's Avatar
There are 2 filaments in the front (you are seeing the parking lamps)
Do the hazard flashers work ??
Old 11-10-2006
MarkieMark's Avatar
Hazards are gone too.
Old 11-10-2006
CraigW's Avatar
The flasher relay unit is common to both turn signal and hazards. Iit is located in the under dash box. Remove the single visible screw (phillips head) and the fuse box will slide down (somewhat) on rails. The flasher unit is the larger of the black boxes that plug into the fuse box on the right side.
You could try removing and inserting the flasher in and out of the socket a few times.
Old 11-10-2006
MarkieMark's Avatar
thanks!
signals are working now.
Old 12-02-2006
Colombian4Lyf's Avatar
Colombian4Lyf is an unknown quantity at this point
Dash box? is that the same as the Glove box?
Is it right under where you remove the black panel? I seen more than one visible screw, I must be looking in the wrong place. Any one have a pic?
Old 12-02-2006
CraigW's Avatar
Drivers side, behind U shaped panel with 2 release locks. The single screw is 10mm (i think) with a Phillips head also.
Old 12-03-2006
Got it, everything is working, thanks guys
Old 01-22-2007
jhwee's Avatar
jhwee is an unknown quantity at this point
Sorry for reviving this old thread, but does anyone have the part # that connects from the in-house wiring harness to the bulb holder?
I have part #33302-SR3-A01 - which is a dual filament 1157A bulb holder. I need the connector for it. Any one work at a Honda dealership? :P
Thanks.
Old 01-31-2007
Formerly 2blu
Nick's Avatar
Thanks.
Bump cuz. I'm in the same situation.
Old 01-31-2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Try here:
Honda Parts Catalog, Honda Parts List, Honda Parts Lookup, Honda Accord Parts List, Honda Parts Diagram
Someone else a while ago was looking for Honda part numbers and was given this site. I've never used it, let me know if it works.
Old 01-31-2007
jhwee's Avatar
^ that's exactly what I needed. +rep.
Thanks a lot!
Well I just ordered the parts. It's a connector (comes in a pack of 5) and pigtail (comes in packs of 3 or something). They had to special order it, and I'm doing it through my co-worker's husband. I'll let you know the exact part number when it arrives.
Old 12-14-2009
2004Ex's Avatar
2004Ex is an unknown quantity at this point
Re: Turn Signals Died
My turn signals and hazards lights are not working. Ive replaced the fuses in the car and under the hood. they still do not work... what else can i try?
Old 12-14-2009
get a new flasher relay to replace the stock one. they only last for a certain number of flashes. the 01-03 civic uses tridon EP34 i believe, most auto store will carry it. flasher is in the under dash fusebox. consult owner manual for the exact position.
Old 11-29-2011
Captain_Mo's Avatar
Captain_Mo is an unknown quantity at this point
I have a similar, yet maybe trivial question; My right turn Signal is out, no clicks, no flashes...but the Hazard lights work, how can I correct that issue?
Old 11-30-2011
CraigW's Avatar
^^ Do both the right bulbs work correctly during hazards ?
Old 11-30-2011
Captain_Mo's Avatar
Both Hazard bulbs on the right side do work correctly, it seems to be only when I want to make a right turn does neither the bulb or the green arrow inside work.
Old 11-30-2011
CraigW's Avatar
What year ?? Trim level ?
Old 11-30-2011
Captain_Mo's Avatar
Its a 2002 Honda Civic EX
Old 11-30-2011
CraigW's Avatar
If you want to Ohm the turn signal switch...
BLK/RED = Common
GRN/YEL = Right
GRN/RED = Left
If switch is ok you will have continuity between BLK/RED & GRN/YEL when right signal position is selected.
Old 03-25-2016
Mmeirele's Avatar
Mmeirele is an unknown quantity at this point
Unhappy Right turn signal does not work with AC on!
Wondering if y'all could help me with this dilemma...
Went to get my oil leak fixed, o2 sensor replaced, and a new belt.
When I pick up my car after it was all fixed I turned on my car (good) then when I turned on my AC, I heard the motor kick in but no ventilation was coming out. It was not like this before I took my car in (AC was working fine). Now the weird part is that the air would blow and stop after a couple of minutes, but now when the AC is "turned on" my right blinker will not work! I see the light very dim when the AC is turned on even when the blinker is not supposed to be on. When I flip my blinker up as if I turned it on, it does not blink on my dashboard or outside of the car. Anyways, it is some electrical issue that is occurring that I have no idea why or how to fix it. Someone please help!!!!
Old 03-26-2016
CraigW's Avatar
^^^^ Almost sounds like a poor grounding, someplace.
trellex
05-24-2015 04:39 PM
steveneddy
05-19-2015 02:39 PM
shaejb15
04-26-2015 07:44 PM
Fastfebur
04-22-2015 01:37 PM
my2k1vic
01-08-2002 08:31 PM
Quick Reply: Turn Signals Died
