A/C not blowing cold air. HELP! - Honda Civic Forum
Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Generation Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
LinkBack Thread Tools Search this Thread
Old 10-08-2006   #1
bymitten is an unknown quantity at this point
Question A/C not blowing cold air. HELP!
I've tried browsing through the forums to find the answer I'm looking for, but had no luck.
My problem is my air conditioner isn't blowing cold air at all! When I purchased my 2001 Honda Civic back in Nov. 05, it worked great, although I never used it because winter was right around the corner. But come spring/summer time when I needed it, I'd turn the a/c on, I can here the compressor turn on and feel the air blowing but it's warm! (yes the dial was turned to cold and the A/C button was illuminated) I'd let it run for a good 30 mins but the air blowing was still warm!
Anyone think they know what's wrong? Thanks in advance.
bymitten is offline   Reply With Quote
Old 10-08-2006   #2
Axe Man's Avatar
Axe Man is an unknown quantity at this point
Yes, chances are your A/C system has a slow leak and the R134A refrigerant is low. Any competent shop who works on A/C systems can quickly isolate the leak and recharge your system.
__________________
2004 Civic Coupe, 5 speed. Stealth black. Saddleman hood protector, Actron Super II tach, Rear Spoiler.
Axe Man is offline   Reply With Quote
Old 10-08-2006   #3
streetglower's Avatar
Images: 3
streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all
Send a message via AIM to streetglower
yes you may have a leak, but you may have other issues as well. just cause you here the compressor kick on, doesnt mean its doing its job. you could have damaged valves in the compressor. you may have a faulty pressure switch. or faulty expansion valve.
__________________
Quote:
Originally Posted by AggressiveAdam
hah yes the K series will make your car fly.
Quote:
Originally Posted by McFLYsi View Post
just got pulled over the other day for having JDM yellow headlights, the cop told me it was illegal to have yellow lights, only white, any comments on this. i was just sittin in my slab with trunk poppin and my candy paint drippin off my doors.
streetglower is offline   Reply With Quote
Old 10-08-2006   #4
Images: 178
gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute
take it to the freeway at 65mph or higher for at least 20 mins. make sure to keep your speed constant whatever you choose. put the cruise on and then turn to ac on full blast with the recirc button also pressed. if after 20 mins it feels a lil colder then youre prolly just low on r134a. if its the same warm air, then theres problem with the system. could be alot of things actually not just compressor.
ive done this when mine was only blowing semi cold air, by the end it was ice cold. also if the ac isnt used at least once a week to circulate the lubricants, there is a higher chance it will fail later on. not using ac the whole winter is a bad idea. remember you dont have to have the dial set to cold, you can set it to heat and still turn on ac just to keep it working properly.
__________________
2002 Honda Civic EX Auto
gearbox is offline   Reply With Quote
Old 10-08-2006   #5
Go Team Venture!
againifall's Avatar
Images: 17
againifall is a glorious beacon of light againifall is a glorious beacon of light againifall is a glorious beacon of light againifall is a glorious beacon of light againifall is a glorious beacon of light
Send a message via AIM to againifall
sounds like a leak.. not a big deal...
you can also recharge it yourself.. r134a.. aka the blue bottle
they also sell recharge kits at autozone and such
againifall is offline   Reply With Quote
Old 10-08-2006   #6
Thumbs up
Wow! You guys are quick to help! Yeah, I knew I should have ran the a/c for a bit once in a while to keep things lubricated, slipped my mind I guess. But thanks for the info, I'll get it looked at after the winter months.
Old 10-12-2006   #7
timbo is an unknown quantity at this point
Also check the blend door to make sure it is switching from hot to cold
timbo is offline   Reply With Quote
Old 10-12-2006   #8
Quote:
Blend door?? From that answer, you can guess that I'm not very mechanically inclind. (in cars anyways). Can you tell me where to look and/or "show" (photos) what to do to check this? Much appreciated!
Old 10-16-2006   #9
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
blend door is basiicaly the door which overlaps the heat and a/c. The blend door might be not working properly.
but get it checked out, probably leaking/low on r134a
__________________
ssm sedan
rice4lyfe is offline   Reply With Quote
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
AC Compressor Issues mrohitredd Mechanical Problems/Vehicle Issues and Fix-it Forum 24 09-05-2015 06:03 PM
1999 CIVIC DX A/C not working andyandyy Mechanical Problems/Vehicle Issues and Fix-it Forum 3 08-04-2015 07:37 PM
A/C intermittent mcollins Mechanical Problems/Vehicle Issues and Fix-it Forum 1 07-24-2015 08:37 PM
'04 Honda Civic Overheating.. please help liagreenhalgh92 Mechanical Problems/Vehicle Issues and Fix-it Forum 6 07-21-2015 02:31 PM
A/C Evacuation and Recharge turd_ferguson Mechanical Problems/Vehicle Issues and Fix-it Forum 4 07-14-2015 04:39 PM
Tags
05 , ac , air , blend , blowing , civic , cold , colder , conditioner , door , honda , make , motor , my , stops
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
vBulletin Skin by ForumTemplates.com
All Content Copyright 2007 CivicForums.com
