Hazard button light and AC button lights flicker
Old 08-31-2006
SepulturaCivic's Avatar
SepulturaCivic has a spectacular aura aboutSepulturaCivic has a spectacular aura aboutSepulturaCivic has a spectacular aura about
Ehh my hazard button light and my ac button lights sometimes go off when i hit a bump, or what not, if i tap the area surrounding it, they usually go back on, is this easily fixable so i dont have to tap them all the time lol?
Old 08-31-2006
it might just be a loose bulb. thats easier than checking the wiring. just take it out and see if there is a loose wire too around the plug.
Old 08-31-2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
^ good assumption. I mean if both are going out with there light that means there shared electrical ground is bad somewhere. Since those two things are on a different harness you could either check the ground connection (I think to be simple there is one behind the 12V socket or take a electrical diagram of the two circuits and compare and find the partner.
Old 08-31-2006
HD~Silverado's Avatar
HD~Silverado is an unknown quantity at this point
Thats almost sounds exactly whats happening to me. My dash lights behind my A/C and recirc (not the ones inside) one day just stopped working. It turns out there is one bulb for those two buttons. Then yesterday it was working again before quitting on me again after I stopped. I then puched the area around the light and they came back on??? Loose bulb I'm guessin.
Old 08-31-2006
Idk its annoying though, it doesnt do it to much but when it does it drives me crazy.
stryder12
06-30-2015 08:33 PM
werdnahall
05-17-2015 11:37 AM
supercivic01
South
11-30-2001 11:27 AM
klam
11-16-2001 03:36 PM
galaga3
10-01-2001 01:56 AM
Quick Reply: Hazard button light and AC button lights flicker
