Someone has got to know the name of this piece
Rep Power: 0 Someone has got to know the name of this piece
Hey all fellow members. I am trying to figure out what the name of the piece that goes bolted onto the headlight thats holds under it. The reason being is I think i need to change it because I had been in an accident and that left side headlight got ripped out. They fixed my car but used the same base piece and I think it is bent because my headlight is angled a bit upward.
So I am hoping that piece will fix the problem because I want to get Hid's and I cannot have it with that light angled upward cuz it will really blind people.
So yeah if anyone can tell me what the name of that piece is and where i can get it online like in Hondaautomotiveparts.com because I looked there and could not find it. If anyone can then thank u
BTW it is the left headlight
Rep Power: 787 the bracket? well is the actual headlight sitting wrong, or is the light just too high. cause there is a level adjustment you can do to aim it back down. its the screw gear thing in the back that you can turn by sticking a screwdriver through the hole in the frame down to the gear.
anyway here it is. i think its 8?
http://www.hondaautomotiveparts.com/...tcgry5=BUMPERS
Civicforums Junkie
Rep Power: 424 go back the the shop that repaired the car...ask them to look into whether or not they need to do some more work to get everything aligned
or, you could try bending the bracket before you go and buy a new one
Rep Power: 0 well the thing is they are aftermarket headlights because the other one got cracked. I have tried looking for that adjustment to make it go downward but it does not have that. I am gonna try to bend it downward a bit but the problem is I will get into more problems cuz then if i bend too much it will aim downward. So I think I might just buy the piece to avoid the hassle. and yeah it was a while back so i know the body shop wont do anything about it. Thanks again for everyone with the help
ricer_em2
05-11-2016 08:09 PM
pilebuck13
09-21-2015 10:45 PM
Dakota21601
08-18-2015 08:41 PM
