Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-23-2006   #1 (permalink)
lumpy007
New Member
lumpy007's Avatar
lumpy007 is an unknown quantity at this point
Help!! idle rough!!
my car died today and found out it was the battery so i put in a new one but now it idles kinda rough almost like its gonna stall out ! To remove this ad, register today for free or log in if already registered!
lumpy007 is offline   Reply With Quote
Sponsored Links
Old 08-24-2006   #2 (permalink)
streetglower
7thGen Junkie
streetglower's Avatar
streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all
Send a message via AIM to streetglower
need to do the idle relearn.
__________________
Quote:
Originally Posted by AggressiveAdam
hah yes the K series will make your car fly.
Quote:
Originally Posted by McFLYsi View Post
just got pulled over the other day for having JDM yellow headlights, the cop told me it was illegal to have yellow lights, only white, any comments on this. i was just sittin in my slab with trunk poppin and my candy paint drippin off my doors.
streetglower is offline   Reply With Quote
Old 08-24-2006   #3 (permalink)
lumpy007
New Member
lumpy007's Avatar
ok what?? and how??
Old 08-24-2006   #4 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
PCM / ECU Reset and Idle Learn
1. start the car and drive it until the engine is at full operating temperature.
2. Park the car, turn off the engine, and pop the hood. Locate the fuse box and lift up the top cover. Using the supplied fuse puller, remove the FI ECU fuse for at least 10 seconds.
3. Replace the fuse and close the box. Make sure that all electronics and accessories are in the off position. Start the car and let it idle for 10 minutes with the hood closed. Do not press on the gas or turn on any accessories during this time.
4. After 10 minutes, turn off the car. The idle speed should now be set. Start the car and go drive like you normally would so the PCM can relearn the fuel maps.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 08-24-2006   #5 (permalink)
lumpy007
New Member
lumpy007's Avatar
thx alot i will try it in the morning!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
