| You have a VTEC-E motor. Vtec activates at anywhere from 2500 to 3000 rpms. It was never kicking in at 4500 it cant. You were feeling the powerban of the motor. We dont have the cam for high rpm activation. Your thinking you got a SOHC VTEC motor but you have a SOHC VTEC-E economy version!! Which is the only version we have in America. Goes from 12 valve economy mode to 16 valve mode when vtec is engaged around 2500 rpm's. About the clutch mine does that to and you could probably grease the clutch pedal backside or spray some WD40 on it. I think there is a d16w8 wich is a 3 stage Vtec. Its like ours but does kick in to high cam vtec mode. But thats over in the phillipenes or somthing. Good luck!!! |
