Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-08-2002   #1 (permalink)
aoazn
Member
aoazn is an unknown quantity at this point
seatbelt making sounds
Whenever I'm cruising on the highway and open the windows I hear an annoying whistle made by the seat belt. It's just from the part where the seatbelt emerges from the post to the the other part. This is happening when i'm at 60-80. Anyone else have this happening? Or is this the 2k1 or only me?[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG] To remove this ad, register today for free or log in if already registered!
aoazn is offline   Reply With Quote
Sponsored Links
Old 03-08-2002   #2 (permalink)
avenger
Platinum Member
avenger's Avatar
avenger is an unknown quantity at this point
Send a message via ICQ to avenger Send a message via AIM to avenger
try moving your seatbelt, it is caused by the airflow over the belt. My toyota used to do this but i moved the seat back a click and that repositioned the belt enough to stop it
avenger is offline   Reply With Quote
Old 03-08-2002   #3 (permalink)
nycivic
Member
nycivic is an unknown quantity at this point
It's a quirk as a result of the design on most coupes. Because of the aerodynamics there is really no way to get rid of it. It's catching hold of the wind. the front window opening is so large that it takes in a lot of wind and the seat belt acts like a "whistle". You really can't do anything about it. Although, I have the same problem and have had no success in stopping it myself. I've tried moving the seat around and it did nothing.
nycivic is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Timing Belt DIY 2
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Transmission - Jerky - Automatic - HELP!
Warrenty law that Save's your a$$
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
