Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-30-2006   #1 (permalink)
kronickz
Senior Member
kronickz is an unknown quantity at this point
Send a message via AIM to kronickz
does engine check light usually come on when installing aftermarket turbo?
as said in the title To remove this ad, register today for free or log in if already registered!
kronickz is offline   Reply With Quote
Sponsored Links
Old 07-31-2006   #2 (permalink)
familycar
Ultimate Member
familycar's Avatar
familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all
it all depends ont he fuel system that your using. but usually yes it does until you get it tuned correctly. i hope you havent turbo'd you car with out a fuel system!!
familycar is offline   Reply With Quote
Old 07-31-2006   #3 (permalink)
kronickz
Senior Member
what do you mean when you say "fuel system"?
Old 07-31-2006   #4 (permalink)
familycar
Ultimate Member
familycar's Avatar
some sort of engine management system that will account for the extra fuel that is needed
Old 07-31-2006   #5 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of
If done "correct" no
if you want to turbo your car
without proper resurch... yes you will have a "cel"
__________________
02BLKCIVIC is offline   Reply With Quote
Old 07-31-2006   #6 (permalink)
drunkenmagnum
drunkenmagnum's Avatar
drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light
Send a message via AIM to drunkenmagnum
even with tuneing it will still come on from time to time.
mine has been tuned twice and it still comes on every once in a while but i have had it checked on and everything is ok. just depends on y it comes on!!
useually comes on for misfires though.
__________________
196 hp
194 fpt @ 10psi - Before the rebuild
"My d!ck feels like corn"-Dane Cook
R.I.P 7thgencivic.com
Type-S Fuel Injectors for sale.
WTB: 02-04 ep3 (si) rear brake assembly
T.E.A.R.S crew member #1
Car for Sale
drunkenmagnum is offline   Reply With Quote
Old 08-01-2006   #7 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
If you have to ask the question, then yes, its going to be on... probably all the time. Time to do some homework before you **** it up royally.
Boilermaker1 is offline   Reply With Quote
Old 08-01-2006   #8 (permalink)
kronickz
Senior Member
well i hooked up a 12:1 fmu if that makes a difference. and i'm only running a 14b turbo with 4 psi and a sidemount.
Old 08-01-2006   #9 (permalink)
familycar
Ultimate Member
familycar's Avatar
Quote:
well unless you converted to a return system or at least a makeshift return system then the FMU isnt doing you any good. you probably also need a missing link to run with the FMU to trick the map sensor and bleed off boost so the ecu doesnt freak out. but an FMU is the biggest band aid in the whole FI market. youll get flat spots and leans spots in your air fuel ratio causing lost power and possibly make the injectors clip if your running too much pressure. you need to do some serious homework man. it sounds like you really dont have a clue what your talking baout or what problem you are really facing. go buy " Maximum Boost" by corky bell. it should help explain a few things and hopefully get you pointed in the right dirtection and away for the current set up you have.
Tags
engine , light , management
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Timing Belt DIY 2
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Transmission - Jerky - Automatic - HELP!
Warrenty law that Save's your a$$
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
