Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-27-2006   #1 (permalink)
EM2jdm
Super Member
EM2jdm is an unknown quantity at this point
suspension problems
i've been noticing this clicking noise everytime i start driving my car from a complete stop. so the other day i had my brother drive my car so i could take a look outside and noticed the front passenger side wheel moves back and forth about 1"- 2". i got the car on jackstands and looked under the car but nothing seems broken so maybe you guys would know something about this problem. thx To remove this ad, register today for free or log in if already registered!
__________________
I <3 My EM2&EF9
http://img102.imageshack.us/img102/593/em2jdmcm6.jpg
EM2jdm is offline   Reply With Quote
Sponsored Links
Old 07-27-2006   #2 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of
this was the first thing that came to mind when I read what was going on...
http://www.7thgencivic.com/forums/sh...d.php?t=243399
good luck!
__________________
02BLKCIVIC is offline   Reply With Quote
Old 07-27-2006   #3 (permalink)
familycar
Ultimate Member
familycar's Avatar
familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all
if it pops its your suspension if it is an 01. if it clicks its your cv joints/axles. i bet it gets louder when your turning right???
familycar is offline   Reply With Quote
Old 07-29-2006   #4 (permalink)
EM2jdm
Super Member
its not a cv joints or axles because both were replaced not to long ago and i made sure my suspension was installed correct. i thought it was a alignment issue had it checked out it wasn't it. im thinking its a wheel bearing or something of that sort
__________________
I <3 My EM2&EF9
Old 07-30-2006   #5 (permalink)
savedadogs
Member
savedadogs's Avatar
savedadogs is an unknown quantity at this point
I have the same issue with my 2004 civic ex. It clicks when i move from a complete stop. Have to take to the dealer and let them figure it out. Update once I do.
savedadogs is offline   Reply With Quote
Old 07-31-2006   #6 (permalink)
02BLKCIVIC
02BLKCIVIC's Avatar
Hmmmm
wheel bearing??
dont know without being there...
again good luck!
__________________
Old 07-31-2006   #7 (permalink)
cannonfolder
New Member
cannonfolder is an unknown quantity at this point
does it move up and down? If so then it is your bearing.
cannonfolder is offline   Reply With Quote
Old 08-21-2006   #8 (permalink)
savedadogs
Member
savedadogs's Avatar
My clicking/popping is supposedly due to a bad strut assembly. Here are the details:
http://www.7thgencivic.com/forums/sh...=274140&page=2
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Timing Belt DIY 2
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Transmission - Jerky - Automatic - HELP!
Warrenty law that Save's your a$$
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
