| I would check all of the fan speeds to see if any are missing, If some are missing or it happens again the first place I would look is the blower resistor most likely located under the passenger side dash. The connector will have 3-5 wires going to it and it will be located in the air path of the blower fan. Could also be the selector switch itself is causing problems. |
