Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-12-2007   #91 (permalink)
megacivicfan
Member
megacivicfan's Avatar
megacivicfan is an unknown quantity at this point
Send a message via AIM to megacivicfan Send a message via Yahoo to megacivicfan
Re: DIY: Diagnose manual Tranny Noises (and save some $$$)
Ok, I've tried searching and getting as much as I could out of this post. I have an '01 Civic DX 5-Spd, with 162,500 miles. It's been eons since I've been on this site (before it changed from 7thgencivic). All original parts on my car (engine, trans, clutch, axles, etc.) I started out having I guess what everyone calls a ticking noise, started in the winter at 100k miles, thought it was noisy valves. I adjusted them(they were towards the maximum allowable value), didn't even need it really, but it seemed to help a little.
I could have sworn it was then noisy injectors, used an amsoil injector cleaner, again helped a little, and fuel mileage went up. I know aftermarket injector cleaners don't do the job a professional shop would do, so I thought I was living with noisy injectors, and as long as the car ran fine, gas mileage didn't suffer or anything, I could keep going.
Now it seems like I do have the input bearing problem after reading this post. No noise when clutch is released. Noise (very muddled kind of loose, rattling bearing noise). Not much noise at all in first gear on very low speed conservative engagement, until I hit 5-10 miles per hour. There in second gear, just as bad, less in third, even less in fourth, probably so much road noise, I really don't hear it at all in fifth. Same clutch release now, but I accelerate harder, and noise is worse, but same pattern in all gears as I previously stated.
The best way I can use to describe the noise at 5-10 mph and up in 1,2,3,4 gears is it "kinda" sounds like a diesel, but not as hearty, and only coming from the injector/cylinder head area. The only point of reference I have is sitting in the driver's seat. So if it is the input shaft bearing, holy sh*t that's noisy!
After describing the noise, does this sound familiar, am I on the right track?
__________________
"That's just like....your opinion.......man." - The Dude
megacivicfan is offline   Reply With Quote
Sponsored Links
Old 09-17-2007   #92 (permalink)
megacivicfan
Member
I talked to the dealer a couple days ago, and the service dept manager hasn't seen or heard of the input bearing problem (at that dealership anyway), at least he said that problem is highly unlikely. Then again, he also pointed to the opposite of what this post points at for my problem.
Got the trans out today. All the grease on the slave cyl pushrod, the ball pivot for the fork, and on the tines at the bearing was dried up. but everything looks pretty good. Wear on the fingers was good, springs looked good, and the throwout bearing looked well used, but it did not feel gritty or sloppy.
I still have to pull the pressure plate off and inspect the rest. I noticed that with the front wheels off the ground, and the car idling in neutral, the front wheels still spin. When I pulled the trans out, I spun the input shaft by hand, and the differential still spins. Is that right?
__________________
Old 10-15-2007   #93 (permalink)
breault5
Member
breault5 is an unknown quantity at this point
hey how much would this cost??? to have a shop do this mine is making the noise when the clucth is out...
breault5 is offline   Reply With Quote
Old 10-18-2007   #94 (permalink)
ultimatetuner10
Technical Assistant
ultimatetuner10's Avatar
ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned ultimatetuner10 should not be questioned
Send a message via AIM to ultimatetuner10
Great writeup helped me diagnose my problem. however, the part numbers for these parts have changed, the guy ordered it by the pic but the part number was nowhere close..il get the updated ones when I pick up my part!
ultimatetuner10 is offline   Reply With Quote
Old 10-18-2007   #95 (permalink)
ultimatetuner10
Technical Assistant
Quote:
Im being charged 420. The reason is the transmission has to be out and open to get to the part...also I hear on our cars you have to drop the subframe to get the trans out, which doesnt make costs any cheaper..however dont say that to a shop because if they tell you 300 and you tell them the subframe has to be dropped they can charge more..if they tell you 300 and then try to charge you more because they didnt know...well thats their fault and you only pay 300. my shop is a very reputable performance shop that deals specifically with hondas so i trust them a lot and am willing to pay more
Old 10-18-2007   #96 (permalink)
breault5
Member
oh ok cool thanks for the estimate...so does this need to be changed or can we just try to not think about the noise and just leave it like it is?????
what are the consequences if we dont fix it if any???
Old 10-18-2007   #97 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of
a busted tranny over time!^
__________________
02BLKCIVIC is offline   Reply With Quote
Old 03-28-2008   #98 (permalink)
12345678910
Member
12345678910 is an unknown quantity at this point
any chance a worn ISB would throw a check engine light???
12345678910 is offline   Reply With Quote
Old 03-29-2008   #99 (permalink)
03civicdx_420
New Member
03civicdx_420's Avatar
03civicdx_420 will become famous soon enough
ok i have a bad input shaft bearing too and after reading about all these 7thgens goin bad IS THERE NO RECALL ON THIS??????!!!!?!?!?!?
__________________
03civicdx_420 is offline   Reply With Quote
Old 04-30-2008   #100 (permalink)
ashtonp
Senior Member
ashtonp's Avatar
ashtonp is a splendid one to behold ashtonp is a splendid one to behold ashtonp is a splendid one to behold ashtonp is a splendid one to behold ashtonp is a splendid one to behold ashtonp is a splendid one to behold ashtonp is a splendid one to behold ashtonp is a splendid one to behold ashtonp is a splendid one to behold ashtonp is a splendid one to behold ashtonp is a splendid one to behold
Does anyone have a DIY to take the transmission out?
ashtonp is offline   Reply With Quote
Old 05-21-2008   #101 (permalink)
turboengnr
DONT PANIC
turboengnr's Avatar
turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all
Send a message via AIM to turboengnr Send a message via MSN to turboengnr
Well shit.... Do I have to do everything???
Jack up the car and take both tires off. Pull out the Two 17mm (maybe 19mm, i dont remember) bolts that hold the strut to the spindle on each side and the 10mm bolt that anchors the brake line. Then pull out the cotter pin and pull off the large (23mm i believe) axel nut that holds the axel to the spindle.
Now go to the engine bay and pull out the battery and the battery tray. Then pull off all of the air induction system parts, and basically anything attached to your transmission. Make sure you pull out the Speedo sensor. You could leave it in, but why leave a cheezy ass piece of plastic that costs half a billion dollars in a place where it could potentially be broken?
Next up, put a wooden block on a floor jack and gently apply pressure to the bottom of your oil pan. Then take off the Front, Rear, and Passenger's side trans mounts. You will want to get another floor jack (i LOVE my cheap ass harbor freight Racer's special aluminum low profile jack for this) and use it to hold up the trans. Now you need to take out the axels and unbolt the trans.
Now i have a nice trick for you.... Loosen the 4 17mm bolts that connect the subframe to the body, and that will give you enough room to pull the trans back far enough to do anything you need to do, without having to pull it completely out of the engine bay.
__________________
<--- Now known as Myika.
Quote:
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
7thgen civic 13 second club Member #1
13.624 @ 101.887
I suck at sleeping Crew Member #1
I love my wife... Click here to find out why!!
turboengnr is offline   Reply With Quote
Old 05-22-2008   #102 (permalink)
red02clutchex
New Member
red02clutchex is an unknown quantity at this point
This is my first post here but I am a former member of 7thgencivic.com so whats up guys and girls! less then a week ago I had my manual five speed rebuilt by a honda dealer. I still hear a noise at 2500 rpm that sounds like rattling. not before that rpm or after and only when the clutch is engaged. the car made this sound about a week before I knew the tranny was shot in the past. I had all bearings replaced as well as the clutch and preasure plate. I bought my 02ex coupe brand new in 02 and never had tranny probs. before now. I recently moved to my area and don't really trust the dealer I took it to but don't know any small machanic to take it to. Does it sound like a transmission prob or could it be something smaller like a heat shield, cat. etc? The car barely has 103,000 miles on it and I have ALWAYS takin good care of it. I'm getting ready to sell the car to a close friend and get a 07 SI sedan, and don't want to hand him my probs. This has been a great car for me and I'm sure it will be for him. Any similar expierences? Ideas?
red02clutchex is offline   Reply With Quote
Old 05-31-2008   #103 (permalink)
johnnyboy5000
New Member
johnnyboy5000 is an unknown quantity at this point
Quote:
Originally Posted by johnnyboy5000 View Post
I'm at 119,000 and still running strong with this diagnosis. Everything is running fine. Knock on wood.
I'm at 140,000 with this same diagnosis and I'm still going strong. So it's been 40,000 miles, just about two years and my car still performs the same. Symptoms still the same, noise when clutch is out and once in a while, usually just when the car is started in the morning, driving down my street, 2nd gear doesn't accelerate. Stepping on the gas makes the engine rev, but the car slows down. I guess the transmission and the engine aren't connecting. However, when I step on the clutch like two times in neutral, then put it back into second, everything is fine, second engages. And it only does this in the morning. Like if I were take it to the shop and have them recreate the problem, they couldn't. It does it only in the morning, when the first time it's in second gear, then not again for the rest of the day.
So it's been like this for two years. I hope don't jinx myself by posting this..
johnnyboy5000 is offline   Reply With Quote
Old 06-19-2008   #104 (permalink)
Superjester
New Member
Superjester's Avatar
Superjester has a spectacular aura about Superjester has a spectacular aura about
Send a message via MSN to Superjester
Hi everyone! I don't know how long Photobucket will keep these Pictures up but...
Guess what? Yup. It happened to me. Around the 100k Mark.
Now thank GOD for this Forum and the explanations else I would probably cry.
Anyways, Everything was fairly simple. So if you wish to do this on your own. Don't sweat it!! It would have actually taken me about 3-4 hours to have the tranny out however due to some run-ins (I will get into later) I spent about 6 hours on this project. Just Remember, This is Mechanics. ALOT of manufactures make things a certain way to fit it. If it doesn't fit in. Don't put it in. If you don't really feel confident. Don't do it. ask around. etc etc you get the point.
Now. First thing if first.
Will it hurt my engine if I leave it? No. But you should change it. It gets annoying telling poeple that your "V-tec" is kicking in. (I don't even have "v-tec")
What does it sound like? What is my Plastic cage is not broken? It could STILL make this annoying noise. Well I have uploaded 2 Videos of mine on Youtube right here.
Please excuse the video sync, It was from a camera.
http://www.youtube.com/watch?v=nmL5CSVG-bw
http://www.youtube.com/watch?v=t3tAV7idcSs
Now I also provided some pictures too. I know there are ALOT already of excellent write ups but A little extra on the help just in case wouldn't hurt.
These are JUST tips I provided. I did things my way and had to do what I had to do. so it's not step by step here.
If you want good write ups by Excellent authors please just search in google for "input shaft bearing Honda Civic" or back to the first part of this thread.
3 Runs ins I had.
Tranny falling
Hub bolts
"O" ring.
This is the "hub". You have to take out the axle to the Tranny. These are the bolts I am currently pointing at. Mine were rusted with MAX POWER! Be careful. I have to LITERALLY heat mine and almost torch them off (thank god for propane bottles) and use a impact wrench to get them off.
The transmission might be hard to wiggle out. It's kind of heavy. Use a jack if you have to. It might hit the side of the frame (Red circle). So you will however most-likely and probably have to jack up the engine.
release this bolt to jack up the engine a little.
don't jack up the engine all the way, but just "enough". You don't want to start ripping lines out.
OH YEAH! once the transmission is out...
You might want to knock on the door and check your clutch too just to see how she is doing down there. be a long time before you see her again. Mine was okay. Still meat left on that body. Its simple to do. with a marker (yellow or white) Mark a line from the clutch to the flywheel. This way here it will be easier to see which way she came off. 8 point wrench (I forget the size lol) just undo the bolts on the outer side of the clutch. Now when taking apart the clutch is simple. putting it back in will be the same way. on the clutch itself the "bigger outside" will be towards the forks (or the tranny). line up the white mark line (there are also 3 pins to help you line up the clutch) and bolt her back on.
It really is simple once you figgure it out. like kindergarten building blocks.
This is a "o" ring. See him? My bad drawn arrow is pointing at him. He is NOT your friend. Needle nose Pliers or ring pliers will do. This is to pull out the input shaft gear. Hold it apart to pull the gear out.
This is the tranny. Note that you MIGHT not want to take out the gears. I did however just to check up on them. In case. I'm fairly confident I can put it back together without mistakes. Nothing is currently on it.
This is the tranny without the outershell case. The red circle is where the bearing is located. To get the bearing out, I used a 5/8 socket on the OTHER side of the tranny. Tap the socket and the bearing should pop right out. Whatever you do do *NOT* pry on the the transmission to get it out. you could damage the transmission.
This is the Input shaft and where the bearing sits on it. Thank you to my brother for playing around with the shifting on it. I hope I can set the syncs back up and not fuck anything up
So I went to the Honda Dealership. Apprently they don't know or never heard of this "Issue", Which is understandable. Most people around here that own Civics are older crowed. The younger tend to the older civics.
So I orderd the part. Cost me 45$ (canadian) Which I felt was weird. I had a bad gut feelings. Because they didn't have 'it in stock" It would be in by TOMORROW at 8am. thats cool. I go back today. THEY ORDERD the WRONG part. Ugh! I *knew* this was going to happen.
they ordered "number 6" the countershaft bearing (refer the the manual on front page) part instead of number 5 Input shaft bearing. so they went and checked the bearing and RE-order it. When he showed the screen I noticed the price said "21.xx" (barley seen it) and I am pretty sure it was that bearing. Now i have to wait till tomorrow before I can put everything back together. thanks alot. Jerks. (I even showed him on his screen what to order).
Anyways....Thanks again guys. I really do love the write ups. Props again to the people who did them
Superjester is offline   Reply With Quote
Old 07-08-2008   #105 (permalink)
ashtonp
Senior Member
ashtonp's Avatar
^^^ RESPECT for the write-up!!
Are you gonna post any more pics on your progress on putting everything abck together?
Tags
auto , bearing , civic , clutch , growling , input , press , shaft , sound , squeaks , throw , throwout , tranny , trans , versus
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
slight change FALKEN Honda Civic Member's Rides 12 01-18-2006 01:47 PM
Cavalier growl? kornsined General Automotive Discussion 17 01-20-2005 12:29 AM
slight hesitation at 50 zkasparks Mechanical Problems/Vehicle Issues and Fix-it Forum 0 11-07-2004 09:48 PM
High whine in engine...Check that Tranny DowntownRicer General Automotive Discussion 5 04-30-2003 01:35 PM
slight drift... 2k1USMCivic Honda Civic DIYs and Civic Tech Chat 9 01-01-2002 02:24 PM
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
