Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-07-2005   #1 (permalink)
Chun_Kit
New Member
Chun_Kit's Avatar
Chun_Kit is an unknown quantity at this point
Send a message via AIM to Chun_Kit
My Wheel Shakes
Hey well this isn't really a big issue but my wheel shakes when i start breakin..mainly on the freeway or when i'm going like over 50..or something..but it's wierd..i've been feeling this ever since i got my greddy evo2...well i'm pretty sure this is the reason but is that a bad thing?..or is it normal?.. To remove this ad, register today for free or log in if already registered!
__________________
2005 Civic
To Do List:
Headers
Sway Bars
Tires
Done List:
Tein Super Streets
-> Progess Camber Kit
Window Tints : 5 Windows
Added a GushiAuto Sticker (Plus 10 Horses)
AEM v2 Intake
Greddy Evo2 Exhaust
Chun_Kit is offline   Reply With Quote
Sponsored Links
Old 10-07-2005   #2 (permalink)
mugenman
"mmmBAHHHH" - vtec y0
mugenman's Avatar
mugenman should not be questioned mugenman should not be questioned mugenman should not be questioned mugenman should not be questioned mugenman should not be questioned mugenman should not be questioned mugenman should not be questioned mugenman should not be questioned mugenman should not be questioned mugenman should not be questioned mugenman should not be questioned
Send a message via AIM to mugenman Send a message via Yahoo to mugenman
when ur braking it could be warped rotors. or out of alignment maybe u knocked off one of ur balencers on the wheels. im experienceing the same thing at the moment. im hoping when i put my steelies on this weekend itll fix that if not then its going to goodyear to scrape up onto the alingment rack heh
__________________
Cincinnati SCCA
#3 STS moved to STX then moved to DSP
WTB:
set of light weight 15 x 7 wheels the cheaper the better must be 4 x 100
mugenman is offline   Reply With Quote
Old 10-07-2005   #3 (permalink)
streetglower
7thGen Junkie
streetglower's Avatar
streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all
Send a message via AIM to streetglower
Quote:
if your wheel shakes when you start breaking, then you have too much runout on your rotors. Its not a bad thing, mine have extreme runout and it shakes bad when I brake. I just havent been able to replace them yet. Just find out how much material you have left on them and see how much runout there is and then based on that, you either need to replace them or you can machine them.
__________________
Quote:
Originally Posted by AggressiveAdam
hah yes the K series will make your car fly.
Quote:
Originally Posted by McFLYsi View Post
just got pulled over the other day for having JDM yellow headlights, the cop told me it was illegal to have yellow lights, only white, any comments on this. i was just sittin in my slab with trunk poppin and my candy paint drippin off my doors.
streetglower is offline   Reply With Quote
Old 10-07-2005   #4 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Every time lately that I have had rotors turned they fail again soon after, I have gotten into the habit of just buying new rotors. They are made very cheap these days.
CraigW is offline   Reply With Quote
Old 10-07-2005   #5 (permalink)
A03
Senior Member
A03's Avatar
A03 is an unknown quantity at this point
It could also be a messed up tire. My car has around 47k on original firestones, and I just had my front rotors cut for the second time (replaced first time, stock cuts second). It was shaking under braking and a little at higher speed just cruising along like you're saying. After getting the front discs changed, the mechanic test drove the car and thought a wheel might have been out of balance. He re-balanced all of them and it still had a little shake feeling. He decided it was a "bad belt" in one of the tires. It was also determined that it was a rear tire, because if you moved a rear tire to the front as you'd do when rotating, the problem got amplified which he says should happen if a belt has broke or gone bad.
I was going to be buying tires really soon anyway, before the snow fall... so he advised I just do it now and fix the problem. My tires are still on a UPS truck somewhere, but I think he's probably right with his assumption.
Just another idea for ya.
A03 is offline   Reply With Quote
Old 10-07-2005   #6 (permalink)
streetglower
7thGen Junkie
Quote:
I do the same thing. I use rotors once and then replace them. I do it because brembo rotors are cheap and spending $90 is no big deal.
But again it is only $10 a rotor or so at some auto parts stores, so I recommend it if people are low on money.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
car shakes at high speeds fastcivic03 Mechanical Problems/Vehicle Issues and Fix-it Forum 23 01-15-2005 03:00 PM
Question about bearings? streetglower Wheels,Tires & Brakes 8 04-26-2004 12:02 AM
Vibration while braking... Majarvis Mechanical Problems/Vehicle Issues and Fix-it Forum 3 04-12-2004 02:58 PM
Got a small problem JohnnyLee South Cali 15 02-26-2004 07:59 PM
Shaking steering wheel and off alignment Eightball Wheels,Tires & Brakes 7 09-21-2003 05:11 PM
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Timing Belt DIY 2
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Transmission - Jerky - Automatic - HELP!
Warrenty law that Save's your a$$
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
