Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-04-2005   #1 (permalink)
crizoss
New Member
crizoss is an unknown quantity at this point
three codes on 2001 civic ex
hey everyone just took my car to a mechanic to have the check engine light tested and whatever was wrong fixed. I got the car back with these three codes P1298, P1259, P0420. He said that it was due to all the aftermarket amps and lights on my car and the alternator can not handle the load. I was just wondering if anyone has had this problem and what can be done to fix it. To remove this ad, register today for free or log in if already registered!
crizoss is offline   Reply With Quote
Sponsored Links
Old 09-04-2005   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
there's a sticky somewhere in tech that says what all the codes mean.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 09-04-2005   #3 (permalink)
streetglower
7thGen Junkie
streetglower's Avatar
streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all
Send a message via AIM to streetglower
http://www.7thgencivic.com/forums/sh...d.php?t=182026
refer to this list anytime you have a check engine light. Now the 3 codes you have are
P1298: Electrical load detector (eld) circuit high voltage
P1259: VTEC system malfunction
P0420: Catalyst System efficency below threshold
I dont really know what you have on your car because you didnt really say much, but all 3 codes are all different from each other. if you want I can go through the troubleshooting for each code for you, P1298 and P1259 will require a bit of diagnosing to figure out the problem, as P0420 is something that takes about 5 minutes to figure out. P0420 is for your cat converter and it is either bad or you have a intermittent failure. P1259 has to do with your VTEC system and P1298 has to do with the electrical load detector circuit in the fuse box.
Now if you had the car at the mechanic for him to fix your problem, then why didnt he fix it? 2 of those codes have nothing to do with aftermarket lights or amps. Maybe you need a new mechanic.
__________________
Quote:
Originally Posted by AggressiveAdam
hah yes the K series will make your car fly.
Quote:
Originally Posted by McFLYsi View Post
just got pulled over the other day for having JDM yellow headlights, the cop told me it was illegal to have yellow lights, only white, any comments on this. i was just sittin in my slab with trunk poppin and my candy paint drippin off my doors.
streetglower is offline   Reply With Quote
Tags
2002 , civic , code , codes , fix , honda , p0420 , p1259 , p1298 , p1298p0420
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
PCM ECU Codes CEL BLINK Code ...and Rant mal Honda Civic DIYs and Civic Tech Chat 5 06-23-2005 10:19 AM
Audio Wiring Color Codes? fripfrap I.C.E. & Electrical 3 07-13-2004 02:29 PM
help with model codes aznTrance Canada East 12 02-14-2004 10:43 PM
"Saved By the Bell" trivia IronFist Off Topic 115 09-14-2003 11:36 PM
Got a ? about the 7th Gen Civics... M1kEzPr1NcEzZ Honda Civic Member's Rides 1 12-06-2002 08:44 AM
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
