How low should your gas pedal go down?
Old 08-25-2005
DMB
DMB's Avatar
DMB is an unknown quantity at this point
I was just wondering how low should your gas pedal go down when you press on it/drive. (2002 Honda Civic Coupe)
My gas pedal is kind of low (alittle lower than the brake)..... I have to press down alittle bit to go...... I was wondering if you allhave this situation/problem, or if it's normal.
How often do you get this checked/fixed?
I'm getting 4 new brake pads installed next month (preparing for the winter)
Old 08-25-2005
Autocross Junky
Zzyzx's Avatar
not sure what your asking here... but Yes the gas pedal sits lower then the brake...
Old 08-25-2005
master of the culinary martial arts
masarak's Avatar
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
And if you haven't messed with your throttle body cable, the gas pedal should have a little bit of "give" in it between when you start pressing on it and when the engine responds.
Old 08-26-2005
PANMAN's Avatar
PANMAN has a little shameless behaviour in the past
You Should Tighten Your Throttle Cable, It Will Give You A Better "sence" Of Throttle Responce. Make Sure It Is Tight Though Or You Will Be Going Through Traffic, And The Next Thing You Know, Your Gas Pedal Does Nothing
Old 08-26-2005
Pinkslip Racer
karizzle's Avatar
karizzle will become famous soon enoughkarizzle will become famous soon enough
and that, my friend, would suck
WaryDriver
23
07-22-2015 07:18 PM
carlinag13
06-18-2015 09:49 AM
cukaracha
06-04-2015 08:25 AM
Bradel26
05-30-2015 10:24 AM
anddrrey
05-11-2015 02:30 PM
Quick Reply: How low should your gas pedal go down?
