Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-18-2005   #1 (permalink)
DMB
Member
DMB is an unknown quantity at this point
My gas door won't open, It broke!
The switch to pop the gas door from the inside doesn't work..... So I had to have some towing company guy un-hook/split the wire from inside the trunk where it's continiously open now.
How much do you think it will cost to have that new wire spring replaced on the left side of the car?
$150?
DMB is offline   Reply With Quote
Sponsored Links
Old 07-18-2005   #2 (permalink)
CiViCPrAnInG2k1
CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned
Send a message via AIM to CiViCPrAnInG2k1
i had the some problem with the gas door too when i bought the car. i brought it to the dealer and they just put in a spring. but in my case, it wasn't working in the first place. is yours working before then broke?
CiViCPrAnInG2k1 is offline   Reply With Quote
Old 07-18-2005   #3 (permalink)
DMB
Member
Quote:
I bought it used last year. I think the warrenty ran out. (pretty sure). It just stopped opening like 2 weeks ago. But it got to the point where i had to fill my gas tank, and couldn't open the door, so had to resort to having it permantly opened....... But I need the spring FIXED. How much?, or should I just have the used dealership do it for me?
Old 07-20-2005   #4 (permalink)
AggressiveAdam
Platinum Member
AggressiveAdam's Avatar
AggressiveAdam is on a distinguished road
the part costs about $40 cdn.
I got my body shop to put it in while they were doing some other work. Find a mechanic or bodyshop who wants to do it, DONT TAKE IT TO HONDA, they want like 1.5 hours of labour. The cable involves replacing the line from the gas /trunk release to the gas door and the trunk pop.
AggressiveAdam is offline   Reply With Quote
Old 08-09-2005   #5 (permalink)
SIR_Grrl
New Member
SIR_Grrl is an unknown quantity at this point
I had the same problem with my hatch... brought it into the dealer and they fixed it... put in a new spring as well... no charge.
Too bad they don't fix everything like that!
SIR_Grrl is offline   Reply With Quote
Old 08-09-2005   #6 (permalink)
stl01civic
BOOSTED DOHC i-VTEC
stl01civic's Avatar
stl01civic is an unknown quantity at this point
the spring is cheap. I believe the spring connect to the trunk and gas. Buying the spring/wire is only $26-30 (from Honda). Me and my friend did the job, pretty easy (~40mins).
You can also open the gas door from the trunk.
stl01civic is offline   Reply With Quote
Old 08-09-2005   #7 (permalink)
Jrfish007
Jrfish007's Avatar
Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all Jrfish007 is a name known to all
Send a message via AIM to Jrfish007
I know on older civic's there was a fuel door realse in the trunk too, might want to look into that. But the spring should be cheap, you can probably just call the dealer and ask for a quote over the phone, it will be more acurate than anyone here.
Jrfish007 is offline   Reply With Quote
Old 08-29-2007   #8 (permalink)
makrovi
Member
makrovi's Avatar
makrovi can only hope to improve
Send a message via AIM to makrovi
Re: My gas door won't open, It broke!
My door doesnt open anymore, when I went to look at the switch by the door, I saw the splitter thing is just plastic and it cracked. Anybody got a part number, or a site online to order this part?
__________________
Rice is good when its warm and with a fried egg on top.
makrovi is offline   Reply With Quote
Old 08-29-2007   #9 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
If a 7th gen Civic maybe this --> http://www.fueldoorfix.com/
CraigW is offline   Reply With Quote
Old 08-30-2007   #10 (permalink)
Rufus
I drink Windex...it keeps me from streaking...
Rufus's Avatar
Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of
Depends on where it broke. The fuledoorfix is perfect if your scenario fits, but otherwise you need a new cable. I bought a new cable for about 26 bucks a month ago. It's been too hot in AZ to fix it so it sits in my office and I open the gas door from the trunk.
__________________
Rufus is offline   Reply With Quote
Old 08-30-2007   #11 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all
Quote:
haha, my thoughts exactly! Mine just stopped working when I hit North Carolina and now that I'm in Georgia it's been way too hot to work on so I just avoid driving it and open it from the trunk when I have to.
Mine's weird though, I can reach into the trunk and pull the cable out from the door and the door will pop open. But then I can't close it because the spring keeps popping it open after I push it shut. But if I hold it closed with one hand and put the cable back in place with the other hand it stays. It just won't open with the lever by the seat.
__________________
7th Generation Member Against Street Racing Number 43
www.em2ab.com
Fully integrated carputer with W-Fi, GPS, 2000 songs/music videos, and weather
7 inch Xenarc 700TSV VGA in dash touchscreen
Compustar 2 way paging alarm/starter system
35% tint excluding windshield
D.I.Y. Blacked Out Headlights
D.I.Y. Debadge
D.I.Y. Remote Trunk Release
D.I.Y. Trunk Air Shocks (Scouting Parts)
Air Ride Suspension Setup (Awaiting Parts)
DeX is offline   Reply With Quote
Old 08-30-2007   #12 (permalink)
tastyratz
New Member
tastyratz is an unknown quantity at this point
anyone ever buy from the fueldoorfix.com website? My girlfriend has the same problem. She has an 01 and the cable broke. Guess what we replaced that same cable for the same reason 6 months to a year ago. This is BS and it shouldn't be an annual fix!
tastyratz is offline   Reply With Quote
Old 08-30-2007   #13 (permalink)
makrovi
Member
makrovi's Avatar
Placed an order for one today. I don't remember where it broke, but looks like on the cable, that is the only place that can break since that is where they use plastic. STOOOPID HONDA. THe other end is metal attached to a thick plastic sleeved cable. I'll keep you posted when it comes.
__________________
Old 09-01-2007   #14 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
So is that what breaks? The cable? I have to rerun a new one all the way through the car?
__________________
www.em2ab.com
D.I.Y. Debadge
Old 09-01-2007   #15 (permalink)
kryngle
Member
kryngle's Avatar
kryngle is an unknown quantity at this point
Send a message via ICQ to kryngle Send a message via AIM to kryngle Send a message via Yahoo to kryngle
Quote:
This is the second time mine has cracked. The first time it was still under warranty and now I have been runnin my car like thos for months. All I do is go in my trunk and release it. Mine is a 2001 EL so I guess its an issue Honda needs to take a look at.
__________________
kryngle is offline   Reply With Quote
Tags
door , gas
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Questions about this. CivicsRdBest Mechanical Problems/Vehicle Issues and Fix-it Forum 5 11-10-2004 02:22 AM
HELP gas lever.. CarpeDiem Mechanical Problems/Vehicle Issues and Fix-it Forum 16 05-25-2004 11:08 PM
Gas Door civicstyle82 Mechanical Problems/Vehicle Issues and Fix-it Forum 10 02-25-2004 10:22 PM
cable broke for truck and gas tank AceKicker Mechanical Problems/Vehicle Issues and Fix-it Forum 2 06-21-2002 10:15 AM
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
