Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Reload this Page
Does anyone's car do this?
LinkBack Thread Tools
Old 01-22-2002   #1 (permalink)
civicman10
Member
civicman10's Avatar
civicman10 is an unknown quantity at this point
When my car is off or just idling in neutral, i can easily put the shifter into a gear without holding down the clutch. Is that normal for our cars? If not i'm gonna go take it into HOnda to have them check it out.
civicman10 is offline   Reply With Quote
Old 01-22-2002   #2 (permalink)
drbombay
Member
drbombay's Avatar
drbombay is an unknown quantity at this point
i know you can do it with the car off. how did you find out it does this? it's an odd thing to try
drbombay is offline   Reply With Quote
Old 01-22-2002   #3 (permalink)
civicman10
Member
civicman10's Avatar
<< i know you can do it with the car off. how did you find out it does this? it's an odd thing to try >>
Heh, well my friend was sitting in the passenger seat while the car was off and was playing with the shifter (he doesn't know much about manual cars). Once i saw him shifting with no problems i got a little confused.
Old 01-22-2002   #4 (permalink)
newkid
Member
newkid is an unknown quantity at this point
u can't shift into gear without stepping on the clutch...when the car is ON
maybe ur friend was just going left to right...but not engaging a gear
dunnnnno have it checked
newkid is offline   Reply With Quote
Old 01-23-2002   #5 (permalink)
SoNiCcIvIc
Member
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
This is what I know from experience...
When I first got my car, I didn't know sh't about using a 5-speed. I tried moving the car to a gear WITHOUT pushing down the clutch (after starting it) and I got the most annoying sound a new car could make. It doesn't sound... right. If the engine is on, and you put it to a gear, isn't the car gonna try to move? (Let alone stall.) I don't get it. I don't have my car with me now to really confirm it. Just... go to the dealer and show the service department (unless someone here can make some sense of it.)
SoNiCcIvIc is offline   Reply With Quote
Old 01-23-2002   #6 (permalink)
DoubleOSuk
Member
DoubleOSuk is an unknown quantity at this point
&lt;&lt;I tried moving the car to a gear WITHOUT pushing down the clutch (after starting it) and I got the most annoying sound a new car could make. It doesn't sound... right&gt;&gt;
Ahh, memories. I remember the first day I crunched a gear. The summer of '94 [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
DoubleOSuk is offline   Reply With Quote
Old 01-23-2002   #7 (permalink)
anibal
Super Member
anibal's Avatar
anibal is an unknown quantity at this point
If the engine is off, sometimes you can shift through gears without depressing the clutch if the gears are properly aligned as easy as if you were shifting normally, if they aren't you'll notice they can't get into place, so don't force it into gear. If the engine is running, and do it without depressing the clutch, you'll grind the gears and the engine may stall.
anibal is offline   Reply With Quote
Old 01-23-2002   #8 (permalink)
ILLWILL
Member
ILLWILL is an unknown quantity at this point
i disagree with ya cuz i can do it wit the car on while im driving its and old trick all u got to do is catch the gear change want the revs are going down its difficult to do but one u got it it works for emergencies {like ur clutch messing up or not grabbing}
but wat i do agree is that i daubt you can switch will the car is on idle
so he should get it checked
as far as the car being off
that is natural all standards do it the trans is not spinnin so the clutch is not going to fight it and it would go rite in
if anybody has a question im me
ILLWILL is offline   Reply With Quote
Old 01-24-2002   #9 (permalink)
89HondaLxi
Member
89HondaLxi is an unknown quantity at this point
okay when the car is OFF you can shift into any gear it doesnt matter.....but when its on you shouldnt be able to shift into a gear
89HondaLxi is offline   Reply With Quote
Old 01-24-2002   #10 (permalink)
SneakerPimp
Member
SneakerPimp is an unknown quantity at this point
I'm not sure if mine does that. I would be too scared to try it.
SneakerPimp is offline   Reply With Quote
Old 01-24-2002   #11 (permalink)
89HondaLxi
Member
with the car off you can shift all you want it doesnt matter if the clutch is in or out, the reason is there is nothing moving in the trani other then the shift forks....the gears dont move with the car off so it wont hurt anything!
Old 01-26-2002   #12 (permalink)
Diznavis
Platinum Member
Diznavis is an unknown quantity at this point
<< with the car off you can shift all you want it doesnt matter if the clutch is in or out, the reason is there is nothing moving in the trani other then the shift forks....the gears dont move with the car off so it wont hurt anything! >>
thats good to know, my friend was just doing that in my car today while it was off and i was hoping it wouldnt hurt anything
Diznavis is offline   Reply With Quote
Old 01-27-2002   #13 (permalink)
Hwoody77
Diamond Member
Hwoody77 can only hope to improve
It is possible to shift through all your gears and not use the clutch without hurting the car. You just have to know your car's dynamics and the like...VERY hard to do. And some people when they race don't use the clutch at all...
Hwoody77 is offline   Reply With Quote
Old 01-28-2002   #14 (permalink)
Becky
Member
Becky is an unknown quantity at this point
i have shifted without using the clutch before.....i learned that trick a long time ago. you cant force it in you just have to push slightly up until it grabs...at least thats how i got it to work. and if your car is off yes you can shift between gears. if you go to the dealer they are gonna laugh at you and take your money for "looking" at it
Becky is offline   Reply With Quote
Old 01-28-2002   #15 (permalink)
Amphiprion
Member
Amphiprion is an unknown quantity at this point
I can shift w/out clutch only when the car is off (thank God).
Amphiprion is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Your answer may be here! TSB / Honda Complaint Address / Etc...
Maintenance required light
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
7th gen civics and their common problems...
Who's had a bad transmission? *UPDATED*
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Timing Belt DIY 2
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
