Mechanical Problems/Vehicle Issues and Fix-it ForumIf you've got a problem you just can't figure out, a noise you can't diagnose, or a Check Engine Light that won't go away, ask about it here!
Welcome to civicforums.com!
Welcome to civicforums.com.
I just installed my injen cai 2 days ago and i love the sound. and i read that u need to reset the car's computer so itll get used to more air coming into the engine... do i need to do that or will the computer just get used to it. and i love the noise of my car but after 6k rpm my car makes a sharp metallic noise and i dont know where its coming from. any suggestions? thanks alot guys
Sponsored Links
what if i already started to drive around? can i still disconnect the battery? haha im just scared cause my friend put in aem sri in his car and his car is having problems with idling *idles hella low around 100-200 range when warmed up*and the honda dealer said it was b/c of the after market parts...
another solution i've read, was instead of undoing hte battery, just remove the fuse for the FI ECU from the main fuse box under the hood, and follow that time bit, 5-10 mins running, no gas, etc.. should work fine and you won't have to reset anything else
