Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-02-2003   #121 (permalink)
Derek-CEO
7thGen Junkie
Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned Derek-CEO should not be questioned
yes, there was a TSB posted about it. To remove this ad, register today for free or log in if already registered!
Derek-CEO is offline   Reply With Quote
Sponsored Links
Old 10-03-2003   #122 (permalink)
ThermalRD
Member
ThermalRD is an unknown quantity at this point
Ok, so we basically havent gotten anywhere with this. Well, i have the same F'n problem, as im sure you read several pages back. Im using a stainless cat-back exhaust on my Civic Si (03). Im gonna change back to my stock exhaust, and just hope this shit goes away. If it doesnt, im going to the dealer about the problem. I bought honda because they had a good reputation. I love the car, but this pisses me off to no end!
Matt
ThermalRD is offline   Reply With Quote
Old 10-06-2003   #123 (permalink)
CoupeStylz
Si(R) killer # 1
CoupeStylz's Avatar
CoupeStylz is an unknown quantity at this point
I don't think the exhaust is the source of the problem I am experiencing. When I drive through a puddle, there is a growling noise that comes from the front right fender area of the car, not from the engine area.
__________________
15.726 @ 88.5 mph
CoupeStylz is offline   Reply With Quote
Old 04-04-2005   #124 (permalink)
Veloz_Racer
New Member
Veloz_Racer's Avatar
Veloz_Racer is an unknown quantity at this point
Thumbs down
Yeah i had that problem yesterday on my way to work, and almost had a 2nd problem nearly side-swipping a guard rail. that started to vibrate a lot and it looked like my p seat was having some sort of attack. when i got to work i checked the car to see if i had snagged anything or if something had got caught up in the car, but nothing at all. i have to hit the hodna dealership next week for a srs light and i will ask and see.
Veloz_Racer is offline   Reply With Quote
Old 07-09-2005   #125 (permalink)
cubanmike26
cubanmike26's Avatar
cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light
Not to bring this thread back, but I'm also having the same problem as everyone...I read this whole thread and from what I interpreted no one really seems to know what's going on. I had a custom exhaust installed on my 04 at 10k miles and never had this problem. All of the sudden at 20k, I feel this constant bass type of noise coming from under the emergency brake handle everytime my car's on 2nd or 3rd gear going over water...All suggestions point to an exhaust problem, but could this be related to the transmission?
cubanmike26 is offline   Reply With Quote
Old 07-09-2005   #126 (permalink)
TransformedBG
I Hunt Goats, Rams, And Mustangs.
TransformedBG's Avatar
TransformedBG is a glorious beacon of light TransformedBG is a glorious beacon of light TransformedBG is a glorious beacon of light TransformedBG is a glorious beacon of light TransformedBG is a glorious beacon of light TransformedBG is a glorious beacon of light
Send a message via AIM to TransformedBG Send a message via Yahoo to TransformedBG
nope its exsaust, you got thermal shock on your pipe, and it warped in a new posision, wich is vibrating agains your car, if it vibrates enough it will eat a whole in the pipe.. start the car get underneith and check it out just to be sure. then if im right, which i probably am. bassically you going to have to have the peice replace or reshaped.
__________________
Yeah so im kind of here but im kind of not... Im only here to post my opinions.
K20A swap, Jackson Racing SC, JRRH
277whp w/210ft.tq.
13.50@107.20 mph w/2.2 60ft time <Street tires>
12.92@106.30 mph w/2.1 60ft time <Slicks>
My sponsors:
other valuable sites
www.***********.com , www.importpassion.com , www.emhonda.com
TransformedBG is offline   Reply With Quote
Old 07-12-2005   #127 (permalink)
hk2ronin
Member
hk2ronin is an unknown quantity at this point
This problem used to happen to me but only after i put an skunk2 exhaust on. The mid section pipe was to close the the frame, it didn't help any later when i mangled that section when i bottomed out it only got worse. I got that section custom built at the local speed shop where they kept the skunk2 flanges but welded sum bigger diameter pipe and dropped it off the frame. No more vibrations no more noise in the rain.
hk2ronin is offline   Reply With Quote
Old 07-12-2005   #128 (permalink)
cubanmike26
Well...my custom pipe doesn't rub anywhere, yet started making the noise when going over puddles. Maybe the water gets in at the header-e/pipe connection and then as it's pushed back by the pressure creates the so called "thermal shock"?
Old 10-17-2005   #129 (permalink)
GaryC17
Senior Member
GaryC17 is an unknown quantity at this point
Not that I want to bring this old thread up too, but I just encountered this same problem. But in my scenario, my midpipe hit a large stone on the road, squashing a secton of it. All was well until the next day when it started to rain heavily. All the symptoms that you guys described happened to me. It sounds as though an engine mounting had died on me. I am dead sure it's the exhaust since I have inspected the entire car undercarriage and nothing else was damaged from the impact of the stone. Guess it's time for a 2.5inch piping change.
GaryC17 is offline   Reply With Quote
Old 10-17-2005   #130 (permalink)
FALLAPART7THGEN
New Member
FALLAPART7THGEN is an unknown quantity at this point
rain problem me too
I found the location where it rattles it happend to me a couple of days ago i as well have a aftermarket catback exhaust but i am taking it in where i got the work done most places will cover this. it hitting the heat sheild on the passenger side and acting like a tuning fork.
FALLAPART7THGEN is offline   Reply With Quote
Old 10-19-2005   #131 (permalink)
norek
(¯`·._.·[ I.Ç.E. BÕX ]·._.·´¯)
norek's Avatar
norek is on a distinguished road
Send a message via MSN to norek Send a message via Yahoo to norek
i got rid of the noise by installing a stainless exhaust and an 8" flex-pipe.
norek is offline   Reply With Quote
Old 10-23-2005   #132 (permalink)
FALLAPART7THGEN
New Member
fix
I have 2 1/2 catback i took a pry bar and bent up the heat shield where it was contacting the pipe their is a lip that hangs down that contacts the pipe
Old 10-25-2005   #133 (permalink)
Curiouz_G
Ultimate Member
Curiouz_G's Avatar
Curiouz_G is just really nice Curiouz_G is just really nice Curiouz_G is just really nice Curiouz_G is just really nice
has anyone figured how to fix this on a aftermarket exhaust yet? for example, the greddy evo II?
Curiouz_G is offline   Reply With Quote
Old 10-25-2005   #134 (permalink)
BrianC
New Member
BrianC is an unknown quantity at this point
Hard to believe that this thread originated almost four years ago, yet here I am to report that I am experiencing this very issue on my 100% stock, 45-day old 05' LX sedan (less than 3000 miles). I have printed out this entire thread, both TSB summaries that were referenced earlier in the thread, and will be scheduling an appointment with my dealer for early next week.
BrianC is offline   Reply With Quote
Old 10-26-2005   #135 (permalink)
cubanmike26
^^Good idea...maybe they'll take some action since your car is bone stock.
Old 10-27-2005   #136 (permalink)
dgw
New Member
dgw's Avatar
dgw is an unknown quantity at this point
I have the same problem, sounds like water on the belts.
dgw is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Timing Belt DIY 2
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Transmission - Jerky - Automatic - HELP!
Warrenty law that Save's your a$$
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
