Quote:
Originally Posted by Mike4831 On my way back from college Thursday night I tried to use my cruise control with no luck. I pushed the button on and the green light lit right up. I pressed the set button and nothing happened. So I tried once again with no luck. Tonight my dad and I looked my car over trying to figure out what was wrong. There doesn't seem to be a fuse for it. I have searched a found where one member said the problem was due to a blown fuse with his horn. Well I checked that fuse and it is fine. I am basically out of ideas.
Will disconnecting the battery work? If nothing is left to try then I guess I am going to have to run it by the local dealership in May. |
Well, unfortuantly the cruise controll system is somewhat complex, you problem could be anything from a switch (or ground) all the way to a bad solenoid or just a bad vacuum line. We can probably help you fix/find the problem, but it going to take some time to trace the problem down (from both ends). If I where you, I wold take it to a garage and let them find the problem then if you want you can replace it yourself, with our help. A garage will find the problem far fast than you can, but if you want we can start truble shooting, just make sure you have digital multi meter.
