Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-07-2002   #1 (permalink)
CaptainAmerica
Member
CaptainAmerica is an unknown quantity at this point
Trouble Shifting In Reverse (manual)
I have a 5 speed EX. Not all the time but often enough I have a lot of trouble shifting into reverse. All of the other gears shift very smoothly so I don't think the clutch needs adjustment. To fix the problem I usually need to shift into 1st or 4th while parked before shifting into reverse.
Anyone else with this problem? I'm only at 1400 miles so I figured I'd wait until the 1st service at 5k unless the problem gets real bad.
CaptainAmerica is offline   Reply With Quote
Sponsored Links
Old 01-07-2002   #2 (permalink)
icey
Member
icey is an unknown quantity at this point
Send a message via ICQ to icey
yeah its like that on all the civics i think..cause my dad has an old civic hatch and it has the same thing....i just go into second and then reverse...no biggie
icey is offline   Reply With Quote
Old 01-07-2002   #3 (permalink)
DHOWPB
Member
DHOWPB is an unknown quantity at this point
The transmission has a lockout to prevent the driver from shifting into reverse from 3rd, 4th, and 5th gears, so you don't accidently go into reverse while driving.
[IMG]i/expressions/beer_yum.gif[/IMG] [IMG]i/expressions/beer_yum.gif[/IMG] [IMG]i/expressions/beer_yum.gif[/IMG]
DHOWPB is offline   Reply With Quote
Old 01-07-2002   #4 (permalink)
SuziQ
Member
SuziQ is an unknown quantity at this point
doesn't the manual tell you to wait 3 secs b4 you shift into reverse from neutral?
SuziQ is offline   Reply With Quote
Old 01-07-2002   #5 (permalink)
CaptainAmerica
Member
Typically I park it in neutral so the car is started in neutral and there is probably more than 1/2 a minute between the start time warming up and when I go to back up. It sounds like this isn't such an unusual issue so I won't sweat it. My wife's Subaru has a similar behavior where I often need to shift it to first before I can go into reverse.
Old 01-08-2002   #6 (permalink)
NitehawkVTEC
Ultimate Member
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
Send a message via ICQ to NitehawkVTEC
pretty much every 5spd I've ever driven has this problem. Solution (got this from the manual in my old toyota)...
If you're having trouble engaging reverse, put the car back in Neutral, Press the Clutch to the floor, Release it. Then try Reverse again. Works almost every time (for me at least)
NitehawkVTEC is offline   Reply With Quote
Old 01-08-2002   #7 (permalink)
Diznavis
Platinum Member
Diznavis is an unknown quantity at this point
Send a message via ICQ to Diznavis Send a message via AIM to Diznavis
i wonder if that was why my 88 dodge omni sometimes had problems going into reverse
Diznavis is offline   Reply With Quote
Old 01-08-2002   #8 (permalink)
insan
Member
insan is an unknown quantity at this point
same here, but just make sure the car is siting still before u put in rev..
insan is offline   Reply With Quote
Old 01-09-2002   #9 (permalink)
kori
Member
kori is an unknown quantity at this point
Send a message via AIM to kori
mine does that too, i have a 5-speed LX almost at 10,000 miles and it sticks sometimes when i go to put it in reverse. almost always when i go to back out of my driveway, i have to wiggle it around to a couple gears before putting it in reverse..i think it must be a safety thing, like someone else said, cause like yours, mine goes into all the other gears smoothly, except rev.
kori is offline   Reply With Quote
Old 01-09-2002   #10 (permalink)
Dakker
Giggity Giggity
Dakker's Avatar
Dakker is an unknown quantity at this point
Send a message via ICQ to Dakker Send a message via AIM to Dakker Send a message via MSN to Dakker
<< If you're having trouble engaging reverse, put the car back in Neutral, Press the Clutch to the floor, Release it. Then try Reverse again. Works almost every time (for me at least) >>
Double clutching, I do this in between every gear, while driving, make the shifts MUCH smoother, you kinda have to relearn how to drive but im just as fast now with this as I was the old way, plus my girlfriend doesn't complain about the neck jerks anymore, though i think this was due to the pos tranny in my s-10
Okay well i don't put it in to reverse every time, but i pull it out of gear, clutch in, clutch out, then in then next gear, then release and gas.
Dakker is offline   Reply With Quote
Old 01-09-2002   #11 (permalink)
NitehawkVTEC
Ultimate Member
I've never actually known what double clutching was. thanks. I've been told that it's using the dissengaging and engaging the clutch midway through a gear to keep rpms up. but I knew that one wasn't true.
Thanks
Old 02-03-2002   #12 (permalink)
Todd1
Member
Todd1's Avatar
Todd1 is an unknown quantity at this point
Send a message via AIM to Todd1
ease your foot off the brake!!!! that should help!!!!!
Todd1 is offline   Reply With Quote
Old 02-03-2002   #13 (permalink)
mykel115
Member
mykel115 is an unknown quantity at this point
All manual are like these if having problem shifting to reverse Put it to 1st gear then put it in reverse
mykel115 is offline   Reply With Quote
Old 02-03-2002   #14 (permalink)
CaptainAmerica
Member
I've been using NitehawkVTEC suggestion of putting it neutral, releasing the clutch, depressing the clutch and trying reverse again. Just as he wrote it works almost every time.
Old 02-03-2002   #15 (permalink)
mykel115
Member
Yeah I think that would work. But when shifting to 1st then reverse you don't need to release the clutch. Anyway do what suit you best
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
