Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-06-2002   #1 (permalink)
fordfocussucks
Ultimate Member
fordfocussucks's Avatar
fordfocussucks should not be trusted
Send a message via AIM to fordfocussucks
Radio gets messed up when i turn on the car.
does anybody know why this happens? im listening to the radio just fine but once i start the engine, the music gets static in the background! help? To remove this ad, register today for free or log in if already registered!
fordfocussucks is offline   Reply With Quote
Sponsored Links
Old 01-07-2002   #2 (permalink)
NitehawkVTEC
Ultimate Member
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
Send a message via ICQ to NitehawkVTEC
You listening to AM? if so it's alternator Whine.
NitehawkVTEC is offline   Reply With Quote
Old 01-07-2002   #3 (permalink)
insan
Member
insan is an unknown quantity at this point
bad ground wire or ground
insan is offline   Reply With Quote
Old 01-07-2002   #4 (permalink)
fordfocussucks
Ultimate Member
no theres static in the background of the music i listen to.
and its am, fm and cd, its everything
Old 01-07-2002   #5 (permalink)
silverdevil
Ultimate Member
silverdevil's Avatar
silverdevil is a glorious beacon of light silverdevil is a glorious beacon of light silverdevil is a glorious beacon of light silverdevil is a glorious beacon of light silverdevil is a glorious beacon of light silverdevil is a glorious beacon of light
Prob. feed back from the alt. Do you still have the stock HU in or did you upgrade? Do you have an amp? And if so, make sure the power and speaker cables run on opposite sides of the car.
silverdevil is offline   Reply With Quote
Old 01-09-2002   #6 (permalink)
fordfocussucks
Ultimate Member
<< Prob. feed back from the alt. Do you still have the stock HU in or did you upgrade? Do you have an amp? And if so, make sure the power and speaker cables run on opposite sides of the car. >>
can you that in english? or just e-mail me
Old 01-25-2002   #7 (permalink)
Puff
Member
Puff is an unknown quantity at this point
Send a message via AIM to Puff
Mine sounds fine, wiring problem maybe 4 U
Puff is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
