Mechanical Problems/Vehicle Issues and Fix-it ForumIf you've got a problem you just can't figure out, a noise you can't diagnose, or a Check Engine Light that won't go away, ask about it here!
Welcome to civicforums.com!
Welcome to civicforums.com.
i post this once but i dont know what happen to it. i had the same problem, 1st to 2nd and sometimes 5th, grinding alittle or trying to pop out. i took it to the dealer. and the said they where going to replace the trans. i thought cool. but the wanted it for a couple more days. the guy working on my car owned an integra that did the same, and he replaced the INER JOINTS. so he order the left joint and it fixed the problem. i don't know why that would be, but it worked. then honda confirmed that there might be a problem with iner joint. so tell the dealer u need the left iner joint part#6469209. and if they have a problem tell them to call the honda corp. they'll change there minds.
Sponsored Links
what exactly are u talkin about caue in my civic i have had it pop out of gear when i push in the clutch at higher rpm's... its so weird cause it doesnt do it all the time............ any one else had that sh@# happen to them????????
