Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-02-2005   #1 (permalink)
ricergribbs
Platinum Member
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
Send a message via AIM to ricergribbs
engine coolant leaking
ok well about a week and a half back i took my car to get the oil changed, i also had the transmission flushed and new tranny fluid put in. ever since, ive been finding a puddle of a clear oily fluid under the car whenever i back out in the morning. i checked the oil level daily, tranny fluid, everything was fine. then last night i was thinking about it and realized it was the engine coolant. so i ran out and checked that, and of course the level is way lower then it was about a month back when i last checked it. i refilled it that time and it was right at the max, and now its slightly below the min. the leak seems to be coming from the rear of the engine, any ideas on what/where could be leaking? To remove this ad, register today for free or log in if already registered!
ricergribbs is offline   Reply With Quote
Sponsored Links
Old 02-02-2005   #2 (permalink)
_Viper_
_Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of
Look at the Heater core hoses there might be a leak there as they are behind the engine..
Check it out
_Viper_ is offline   Reply With Quote
Old 02-02-2005   #3 (permalink)
againifall
Go Team Venture!
againifall's Avatar
againifall is a glorious beacon of light againifall is a glorious beacon of light againifall is a glorious beacon of light againifall is a glorious beacon of light againifall is a glorious beacon of light
Send a message via AIM to againifall
bring it back to where you got it serviced.. if you touch anything it will be on you.. but if they screwed something up its on them..
againifall is offline   Reply With Quote
Old 02-02-2005   #4 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Yikes, it's hard to touch the cooling system from doing oil change, and tranny fluid change only involves loosening one bolt.
gearbox is offline   Reply With Quote
Old 02-02-2005   #5 (permalink)
pon55
Ultimate Member
pon55's Avatar
pon55 is just really nice pon55 is just really nice pon55 is just really nice pon55 is just really nice
Send a message via AIM to pon55
Quote:
Probably tried to get the oil filter from up top and pushed on a hose or something. Does sound like heater hose problem.
__________________
Civic minded old man/ low-loud-loven it!
http://www.myspace.com/pon55
RIP Diana,forever in our hearts and prayers.
pon55 is offline   Reply With Quote
Old 02-02-2005   #6 (permalink)
ricergribbs
Platinum Member
ok actually im no longer sure what the hell it is. at first i thought it was greenish in color, so i kind assumed it was the coolant, but this morning i decided to smell it if it smelled like the coolant, so i put my finger in it, and it was actually like a brown color, almost the same as normal engine oil. but it doesnt smell like it, it really doesnt have a smell, im pretty much out of ideas of what it might be so im gonna jack the car up tonight and have a looksie where its coming from.
Old 02-02-2005   #7 (permalink)
hotrodcivic2004
my civic has no boost
hotrodcivic2004's Avatar
Send a message via AIM to hotrodcivic2004
radiator fluid is hte only crap that looks green. i would take it to the dealer man and have htem check it out. is it still under warranty?
__________________
I may be slow, but it sure does sound good
hotrodcivic2004 is offline   Reply With Quote
Old 02-02-2005   #8 (permalink)
ricergribbs
Platinum Member
yeah its still under warranty, but like i said its not the engine coolant. it just looked green on the ground, maybe cause of dirt or whatnot. but then i got some on my finger to smell it, and it wasnt green, it look almost like normal engine oil just a lighter color. i dont have the slightest clue what it could be, quite a bit has ended up on the ground, and ive checked all my fluid levels and theyre all normal.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Cooling Problem clownprince Mechanical Problems/Vehicle Issues and Fix-it Forum 31 10-02-2005 05:06 PM
Beating Honda at their own game Nodnero South Cali 3 01-16-2005 01:17 AM
water pump problem? Da1lyDr1ver Honda Civic DIYs and Civic Tech Chat 9 01-09-2005 11:02 PM
Carpet Damp? dubz01si Mechanical Problems/Vehicle Issues and Fix-it Forum 7 07-27-2004 11:40 PM
Performed 60,000 mi Maintenance Today WOOHOO!! Storm897 Mid Atlantic 25 07-26-2004 10:00 PM
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Timing Belt DIY 2
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Transmission - Jerky - Automatic - HELP!
Warrenty law that Save's your a$$
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
