Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-14-2001   #1 (permalink)
02Si
Member
02Si is an unknown quantity at this point
What is meant by kick back?
I read this relatively old thread about auto tranny kick back? Auto tranny kick back
I think I may have it.
My exampleis this. I go reverse, brake to stop, change gears to D, let go of the brake, then I begin moving forward, then a very tiny jerk occurs soon after moving forward.
02Si is offline   Reply With Quote
Sponsored Links
Old 12-14-2001   #2 (permalink)
Doc
New Member
Doc is an unknown quantity at this point
Assuming you are coming to a complete stop after backing up before putting the car in a foward gear, it sounds like the transmission has not fully engaged into gear. This may be caused by "low line pressure", this is the pressure of the transmission fluid that actuates gear engagement. It can be adjusted by your dealer through the ECU. There are other causes for this late gear engagement but this is the most common. I would have your dealer check it out, a little bit of time spent to check it out and fix the problem now can save big $$$ later.
Doc is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
