Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-29-2006   #46 (permalink)
Mex
Ultimate Member
Mex's Avatar
Mex is a jewel in the rough Mex is a jewel in the rough Mex is a jewel in the rough
Send a message via AIM to Mex
so what happens if it does not turn off after trying everything in the book? I am referring to my MAINT REQ'D light. I start up, it blinks ONCE, then stays steady-burning. i've held the odometer down for up to a minute while turning my car on in the accesory position, then started and held it for another minute... nothing. please help To remove this ad, register today for free or log in if already registered!
Mex is offline   Reply With Quote
Sponsored Links
Old 08-30-2006   #47 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
unplug the cluster?
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 08-30-2006   #48 (permalink)
djrabbi
djrabbi's Avatar
djrabbi is a name known to all djrabbi is a name known to all djrabbi is a name known to all djrabbi is a name known to all djrabbi is a name known to all djrabbi is a name known to all djrabbi is a name known to all
Send a message via Yahoo to djrabbi
Quote:
well ur supposed to hold it down 20 seconds before u turn on ur car and while holdin it down u start the car and it will go away... thats how my acura is
djrabbi is offline   Reply With Quote
Old 08-30-2006   #49 (permalink)
JAML
New Member
JAML's Avatar
JAML is an unknown quantity at this point
Send a message via ICQ to JAML
Thank you for the tip gearbox
__________________
JAML is offline   Reply With Quote
Old 09-01-2006   #50 (permalink)
Mex
Ultimate Member
Mex's Avatar
i unpluged the cluster, i even removed the battery for 2 minutes. the light is still on. again, it just blinks once, then stays steady burning.
Old 09-01-2006   #51 (permalink)
gearbox
Super Moderator
well if it were me, and I have the old style of cluster 01-02 lx/ex or 01-05 dx, i would open it up and break off the led inside. that light is completely useless. maybe you can sneak in a piece of electrical tape from the back to cover it.
__________________
www.lubecontrol.com
Member 1025782
Old 10-07-2006   #52 (permalink)
Supa_Fli
Member
Supa_Fli's Avatar
Supa_Fli is an unknown quantity at this point
awsome thread gearbox thanx
and blkdrgn thankx man ive been needin these
Quote:
Originally Posted by blackdragon View Post
The engine light is like morse code or something. If u can read it, u could know what exactly its telling you. Mine started blinking 2 days ago and it blinked 10 times meaning something to do with my stock intake.
# Detection Item Probable Cause
1 Primary O2 Sensor Open or Short in O2 sensor circuit, bad Primary O2 sensor
3 Manifold Absolute Pressure Sensor Open or short in MAP sensor circuit, bad MAPS
4 Crankshaft Position Sensor Failed sensor or timing belt slipped, bad CPS
5 Manifold Absolute Pressure Sensor Reading too low or too high, bad MAP
6 Engine Coolant Temp Circuit Reading too low, high, short or open, bad ECT
7 Throttle Position Circuit Reading too high, low, short or open, bad TPS
8 Crankshaft Position Sensor/
Top Dead Center Sensor/
Cylinder Position Sensor/ CKP/TDC/CYP senso circuitdisconnected,open or short. Bad TDC senor.
9 Cylinder Position Sensor Open or short in CYP circuit, bad CYP sensor
10 Intake Air Temperature Sensor Short or open in AIT circuit, bad AITS
13 Barometric Pressure Sensor Circuit Bad ECM (Barometric sensor)
14 Idle Control System Malfunction Bad IAC valve, bad fast idle thermo valve, Throttle body
17 Vehicle Speed Sensor Circuit Short or open in VSS circuit, bad VSS
20 Electrical Load Detector Circuit Short or open in circuit, bad ELD
22 VTEC System Malfunction Short or open in VTEC circuit, bad VTEC solenoid valve, Bad VTEC pressure switch
23 Knock Sensor Circuit Short or open in Knock Sensor circuit, bad Knock Sensor
30 A/T FI Signal A high/low input Bad AFSA line, TCM
31 A/T FI Signal B high/low input Bad AFSB line, TCM
41 Primary Heated O2 Sensor Heater Open or short in Primary O2 sensor heater circuit
45 System too lean/rich Fuel supply system, Primary O2 sensor, MAP sensor, contaminated fuel, valve clearance, exhaust leakage
54 Crankshaft Speed Fluctuation Sensor Open or short in CKF circuit, bad CKF sensor
61 Primary Heated O2 Sensor Slow response, bad O2 sensor, exhaust leak
63 Secondary Heated O2 Sensor Slow response, bad O2 sensor, exhaust leak
65 Secondary Heated O2 Sensor Circuit Open or short in secondary O2 sensor circuit
67 Catalyst System Efficiency System below threshold, bad catalytic converter
70 Automatic Transaxle A/T transmission, A/T FI data line, TCM, ECM
71 Random Misfire (Cyl 1) Ignition system, fuel supply system, MAP sensor, IAC valve, contaminated fuel, lack of fuel, fuel injector, fuel injector circuit, low compression, valve clearance
72 Random Misfire (Cyl 2)
73 Random Misfire (Cyl 3)
74 Random Misfire (Cyl 4)
86 Engine Coolant Temp Circuit Bad ECT sensor, bad cooling system
90 Evap Emission Control System Leak Fuel cap loose, poor vacuum connection, fuel tank, fuel tank pressure sensor, EVAP bypass solenoid valve, EVAP tow-way valve, EVAP control canister vent shut valve, EVAP canister, EVAP purge control solenoid valve
91 Fuel Tank Pressure Sensor Circuit Open or short in FTP circuit, Bad fuel tank pressure sensor
__________________
GO GO GADGET VTEC!!
Supa_Fli is offline   Reply With Quote
Old 01-06-2007   #53 (permalink)
dabflyboy
Member
dabflyboy is an unknown quantity at this point
you da man! thanks. of course, if i wasnt a completely lazy 'tard i would have just read the dang manual. hehe.
dabflyboy is offline   Reply With Quote
Old 01-07-2007   #54 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned
Send a message via AIM to Alpha 5 Send a message via MSN to Alpha 5 Send a message via Yahoo to Alpha 5
Arrow
For the people that are too damn lazy to look in the manual here it is.
ID:	69179   Click image for larger version
ID:	69182   Click image for larger version
Alpha 5 is offline   Reply With Quote
Old 01-07-2007   #55 (permalink)
2002civicLX2002
The only Wyoming Redneck on here
2002civicLX2002's Avatar
2002civicLX2002 will become famous soon enough 2002civicLX2002 will become famous soon enough
^^^^lol, way to be. i figured this out a long time ago, now whenever a honda comes in for an oil change cuz of the check engine light i reset it and there back soon to get another oil change. hahaha
2002civicLX2002 is offline   Reply With Quote
Old 01-12-2007   #56 (permalink)
bcdjr100
New Member
bcdjr100 is an unknown quantity at this point
Send a message via AIM to bcdjr100
Thanks gearbox, I was worried at first when it came on, but I had a feeling it was nothing...
Working first try.. thanks again
bcdjr100 is offline   Reply With Quote
Old 05-13-2008   #57 (permalink)
angel alberto
New Member
angel alberto is an unknown quantity at this point
Re: Maintenance required light
hi , me car have the mat req on , what is the problem? I change the oil , but not the sparg plug , please help me , how I know if I need change the spark plug thanks!
angel alberto is offline   Reply With Quote
Old 08-25-2009   #58 (permalink)
01civictune
New Member
01civictune is an unknown quantity at this point
Nice thanks
01civictune is offline   Reply With Quote
Tags
03 , 2000 , 2001 , 2002 , 2003 , 2004 , 98 , civic , fuse , honda , light , lx , maint , maintenance , req , required , reset
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
