Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-20-2004   #1 (permalink)
02BlueCivicGuy
New Member
02BlueCivicGuy is an unknown quantity at this point
Send a message via AIM to 02BlueCivicGuy Send a message via Yahoo to 02BlueCivicGuy
Exclamation Intake Problems
I just got an aftermarket Intake. The only problem is I dont have the $$ to go to car toys or circuit city and have them install it. So i was wondering if there's anybody that could help give me instructions on doin it myself??? I have the first air box off but im not sure if the 2nd air box (the one with the filter in it) has to come off too? And next what's the rubber hose for that comes with the intake? To remove this ad, register today for free or log in if already registered!
02BlueCivicGuy is offline   Reply With Quote
Sponsored Links
Old 08-20-2004   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
It's so very easy. The resonator and airbox both come off. There are screws holding everything down, and a clamp that holds the airbox on the throttle body. Then there's the iat (intake air temp) sensor that needs to be removed and put in the new intake. Also, there is a hose that goes from the engine to intake (breather hose). There should also be a rubber cylinder that you slip on the throttle body and then push in the intake. Everything should have clamps to secure it.
gearbox is offline   Reply With Quote
Old 08-20-2004   #3 (permalink)
xstrdnr
New Member
xstrdnr's Avatar
xstrdnr is an unknown quantity at this point
look deep on the sides of the filter box there should be more screws on the sides ,it real easy just take your time i did mine my self its an aem intake short ram
xstrdnr is offline   Reply With Quote
Old 08-20-2004   #4 (permalink)
02BlueCivicGuy
New Member
but i dont know if the intake pipe will fit it in kind of a [ shape? And then there's the rubber cap that goes around one of the ends of the pipe, does that go where the old air box lead into the throttle body?
Old 08-20-2004   #5 (permalink)
xstrdnr
New Member
xstrdnr's Avatar
theres 2 pieces a short pipe a long one the short will fit over the throtle with that rubber piece ,and remember to put the clamps over the rubbber first, loosely
Old 08-20-2004   #6 (permalink)
02BlueCivicGuy
New Member
Thanks guys, to late tonight but i'll try it out tomorrow.
Old 08-20-2004   #7 (permalink)
xstrdnr
New Member
xstrdnr's Avatar
oh yea if and when you do it it should hsssssssssssssssssssssssssssssssssssssssssssssssss ssssssssssssssssssssssssssssssssssssssssssss
Old 08-22-2004   #8 (permalink)
02BlueCivicGuy
New Member
yes! it's a sweet hhssssss and so so deep goin all out. you can tell the HP difference right away. It's haulin balls now
Old 08-22-2004   #9 (permalink)
streetglower
7thGen Junkie
streetglower's Avatar
streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all
Send a message via AIM to streetglower
Quote:
what kind of intake did you put on? You sure that HP you are getting is coming from your head. Because I dont know anyone who has put a intake on, and can now say there car halls ass. Especially with our car.
streetglower is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Timing Belt DIY 2
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Transmission - Jerky - Automatic - HELP!
Warrenty law that Save's your a$$
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
