Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-16-2004   #1 (permalink)
gotrice
gotrice's Avatar
gotrice will become famous soon enough
brake light out but not burnt out
my left brake light is out but the bulb isnt burnt out or anything. when i turn my lights on you they turn on but you cant see if i am hitting the brake. even when i unlock the doors or lock you can see both lights light up but its just when i hit the brake that it wont. To remove this ad, register today for free or log in if already registered!
gotrice is offline   Reply With Quote
Sponsored Links
Old 08-16-2004   #2 (permalink)
streetglower
7thGen Junkie
streetglower's Avatar
streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all
Send a message via AIM to streetglower
it should be the bulb. Your bulb has 2 filaments in it. Just like the headlight has a high and low beam. The filament that is used when you press the brake is out. just like when the low beam on a headlight goes out, and only the high beam works. Take the bulb from the other light and put it in there and see if it works. If it does, then it is just the bulb. This most likely is the problem.
streetglower is offline   Reply With Quote
Old 08-17-2004   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Correct. If a new bulb doesn't fix it, then it might be a bad switch. But it's probably the bulb.
gearbox is offline   Reply With Quote
Old 08-17-2004   #4 (permalink)
dirk21
Senior Member
dirk21's Avatar
dirk21 is an unknown quantity at this point
Send a message via MSN to dirk21 Send a message via Yahoo to dirk21
i had the same problem when i had my car and it wasn't the bulbs(it was actually both of my brake lights). if it's not the bulb check your fuses.
dirk21 is offline   Reply With Quote
Old 08-17-2004   #5 (permalink)
gotrice
gotrice's Avatar
ok ill try that as soon as i get a chance but i know its not a fuse i've checked them already. thanks a lot guys
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Timing Belt DIY 2
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Transmission - Jerky - Automatic - HELP!
Warrenty law that Save's your a$$
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
