Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-23-2004   #46 (permalink)
redspeed03
Member
redspeed03's Avatar
redspeed03 is an unknown quantity at this point
Send a message via AIM to redspeed03 Send a message via Yahoo to redspeed03
ya im having the same problem To remove this ad, register today for free or log in if already registered!
redspeed03 is offline   Reply With Quote
Sponsored Links
Old 08-24-2004   #47 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Check your tranny fluid level by warming up the car fully. After driving around, turn off the car and check the dipstick. It should be at the top mark. If it's higher, you need to remove some fluid. Overfill can cause alot of tranny problems--especially shifting.
gearbox is offline   Reply With Quote
Old 08-24-2004   #48 (permalink)
UltimateWarrior
Pimp My Ride!! Please!
UltimateWarrior's Avatar
UltimateWarrior is an unknown quantity at this point
Quote:
Hey man, is it that difficult to flush/change your tranny fluid? I saw some DIY the other day and it didn't look too hateful. I think with our transmissions we might just have to change it more often and really keep up with it. I wonder what the best fluid is on the market and if that might help matters. I'll check that level out when I get home tomorrow, thanks.
p.s. I don't have one of the good floor jacks or even brace jacks to prop the car up on so I can't do much yet. I only have those long, black heavy-gauge plastic ramps you drive up on for oil changes. I got them at Wal-Mart years ago and they work great. I am also going to get a service manual so I can do more to my car. Hell, a timing belt is $19.95 but look what it costs to have it replaced! Not that I would attempt a timing belt change, just making a point.
UltimateWarrior is offline   Reply With Quote
Old 08-24-2004   #49 (permalink)
gearbox
Super Moderator
Doing a tranny fluid change is easy. All you do is loosen a bolt, let fluid drain, tighten the bolt, and pour new fluid in. The hardest part is not overfilling. Just have to drive it (or put it in drive with e-brake) until the car warms up. Tehn turn off and check fluid level. It should be at full after the car is warm. And no I didn't need jackstands.
Old 08-24-2004   #50 (permalink)
streetglower
7thGen Junkie
streetglower's Avatar
streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all
Send a message via AIM to streetglower
Damn I had to jack my car up a bit just so it would be easier.
streetglower is offline   Reply With Quote
Old 08-24-2004   #51 (permalink)
UltimateWarrior
How much fluid does this normally take after it drains? Are we talking so many ounces for a basic comparision? This is just so I get an idea. What happens if you overflow? Oh yea, just drain out some. Doh! Sorry, been a long day...
ps. Sooo, there is no "flush" action. Like blowing it through to clean it better. I always though a flush and fill meant they used a little pressure to clean it. Maybe not. So, just drianing is ok huh? Interesting.
Old 08-24-2004   #52 (permalink)
gearbox
Super Moderator
Bad idea to actually flush it out, cause the tranny components will not like it when you start the car without fluid in there. Takes roughly 3 quarts to fill up. Just be cautious in adding towards the end. Remember, you measure the amount right after the car is warmed up. Cold will give you an inaccurate reading.
Old 08-24-2004   #53 (permalink)
UltimateWarrior
I may give it a shot this weekend. It's been a while since Honda changed mine. BTW, do you have any ideas what the best brands are to use for tranny fluid for our cars? I'll do some searches also, see if I can find any comments on this before someone scolds me for asking!
(Not that you ever have, just a general comment)
Old 08-24-2004   #54 (permalink)
streetglower
7thGen Junkie
best would be Honda Tranny fluid
Old 08-24-2004   #55 (permalink)
gearbox
Super Moderator
Agreed. This is one thing I wouldn't look for something else.
Old 08-26-2004   #56 (permalink)
spyder2333
EM2/DC5/LS1
spyder2333's Avatar
spyder2333 is an unknown quantity at this point
Send a message via AIM to spyder2333
yea i had the same problem and i realized it was my motor mounts i fixed only one but the knocking lessened a little..
__________________
http://www.myspace.com/damegs
http://members.cardomain.com/dimegs
KILL LIST
2003 G35 COUPE
2002 CL 500
2000 CLK 430
2003 FORD F150 HD
2004 MUSTANG GT
2004 SENTRA SPEC V
2004 BMW 545i
GSR HATCH
2004 TL
2005 VETTE
spyder2333 is offline   Reply With Quote
Old 08-26-2004   #57 (permalink)
y.0. KiLLa
Powered by Honda
y.0. KiLLa's Avatar
Send a message via AIM to y.0. KiLLa
yea..i think our honda trannys are strong..i have only seen a few people who have had problems..n these people have gone throught several trannys..so to me its sounds like its the person drivin the car..not the car itself..i love my civic..sometimes i am ruff with it..but it still goes..and it will continue to go for many many many years to come..o0 yea..whoever wanted a ford..good luck..ull be in the shop every week...our civics will outlast any ford..hell my dads 1987 nissan maxima with 210,000 with original motor and tranny with outlast ne new ford focus.
__________________
"Live by da Gun. Die by da Gun"
Mods:
35% tints in front N 15% in the back
17" Rs Limited Pro Concept Rims Wrapped with Hankook k106's
AEM SRI
HKS Axleback
Mods to Come:
DIY Black Out Headlights with Amber
Drop (1.5")
04 Coupe Tails
SSM Painted Interior (Professionally done)
DIY Auto To Manual Shift Boot
Fogs with Lamin-X
Kill List:
'01 Ford Focus ZX3 with aem Cai
y.0. KiLLa is offline   Reply With Quote
Old 08-26-2004   #58 (permalink)
UltimateWarrior
Quote:
Originally Posted by y.0. KiLLa
yea..i think our honda trannys are strong..i have only seen a few people who have had problems..n these people have gone throught several trannys..so to me its sounds like its the person drivin the car..not the car itself...
Well, we will unfortunately have to agree to disagree on this one. I baby the he** out of my car and always had to because of this problem so I know it's not the driver in this case. True, some people do abuse their cars but I still think there is a problem here and so do others. Is it a majority, maybe not. But for a select few out there we tend to agree that our transmission's aren't the best and there are flaws, just like anything else.
I purchased a Honda based on many factors, but the most important ones were reliability and customer satisfaction! Now that I have experienced driving my Honda I am not impressed by the transmission. Now, as you can imagine I am skeptical of ever buying another Honda. I do hope this one lasts and will just have to "baby" it more than I would like to but I have no choice. I know how to avoid the "clunky" tranny but it's very annoying, something I never expected. Again, so much for Consumer Reports! This doesn't surprise me, I have purchased things because of those reports and I've been burned every single time. I cancelled my subscription a long time ago.
Old 08-26-2004   #59 (permalink)
gearbox
Super Moderator
My friend has a 99ex with cvt auto tranny and beats the craqp out of it, shifting the gears by hand and flooring it all the time. I can't believe it, but it still runs to this day. Our tranny would be blown to pieces after a year of that abuse (probably less than a year).
Old 08-26-2004   #60 (permalink)
UltimateWarrior
Yea, they just don't make em' like they use to.
You know why? Most of the stuff is made here now instead of overseas like it use to be. As each year passes more and more things are designed and put together here which I think is causing some of these issues. I love America don't get me wrong but I think the quality is starting to suffer. Honda's aren't the same. They are still great cars but what made them what they are seems to be changing. Stupid Americans... Fat, lazy, out fo shape, only looking forward to 5:00pm so they can go home and down a twelve-pack. It's true!, don't laugh. Other countries have much different work ethics, they take things serious and that's why I think American cars have always suffered and haven't lived up to the overseas' models. I'll always believe this and the more things are made and designed here the more you will see cars that USE to be good start to decline in reliability. Don't believe me? Ok, just wait and see...
Tags
automatic , civic , honda , jerky , problem , problems , transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
