Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen > Mechanical Problems/Vehicle Issues and Fix-it Forum
Register Forgot Password?
Register Photo Gallery FAQ Members List Search Today's Posts Mark Forums Read Experience GarageVendors TSB & Recalls
Welcome to Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 06-16-2004   #1 (permalink)
Extreme Member
ZSKCivic01's Avatar
ZSKCivic01 is an unknown quantity at this point
Send a message via AIM to ZSKCivic01
P1457 Error Code?
Hey everyone, for the past couple of months I have had the check engine light on my dash come on and off constantly. The first time it came on, the error code was P1457, which usually means an evaporation leak usually caused by the gas cap not being tight enough. Well anyways, I haven't had enough time to get my car in for the past couple of months. Just to make sure that this was the same error, I took it back in to autozone and the error is still P1457. The thing is, I made sure the gas cap was tight, even bought a new one to see if the old one went bad. That didn't work though. Does anyone have any idea what could be causing the problem. The code specifically means P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System). Does anyone know what could be causing the light to come on?
ZSKCivic01 is offline   Reply With Quote
Old 06-16-2004   #2 (permalink)
Samari's Avatar
Images: 14
Send a message via AIM to Samari
try resetting the ecu
Samari is offline   Reply With Quote
Old 06-16-2004   #3 (permalink)
Extreme Member
ZSKCivic01's Avatar
Actually today when I went to autozone, the guy erased the code from my ECU so the engine light would go off, which it did. Im assuming that if it doesn't come on anymore, then the problem is fixed. If it comes back on then ill just take it back to honda.
Old 04-11-2005   #4 (permalink)
Skylar1692's Avatar
Images: 2
Skylar1692 is an unknown quantity at this point
Send a message via Yahoo to Skylar1692
I know this is an old post but... Auto Zone's code reader is not too "advanced". The actual "Honda Code" is { P1457 - Unable To Pull Vacuum in Tank } This is caused by either a bad Evaporator Solinoid or most commonly I hole, rip tear break in the Vacuum hose. I had this same code come up and the problem I wound up having was a hole from wear in the Purge Hose (refer to Diag. part # 24) http://www.hondaautomotiveparts.com/...L+PIPE+%281%29
Just thaught this might help some of you.
Skylar1692 is offline   Reply With Quote
Old 04-12-2005   #5 (permalink)
tombgoodu is an unknown quantity at this point
I had the code when I got my 03 Civic, Honda fixed it by replacing the fuel filter and gas cap.
tombgoodu is offline   Reply With Quote
Old 07-19-2009   #6 (permalink)
xcutiepie504x is an unknown quantity at this point
Re: P1457 Error Code?
hi...I have a 03 civic and I been getting a code that says p1457 which is the charcoal canister...i recently change that out and the gas cap also...i thought that would be the problem... two days after the check engine light came back on again so i took it back out to autozone to run a test and it says the same thing p1457...i been having problem with long time crank after refuel... after that the car startes up fine until the next refuel..can you please tell me what is wrong with it....thank you
xcutiepie504x is offline   Reply With Quote
Old 07-21-2009   #7 (permalink)
deedeemac is an unknown quantity at this point
Yesterday due to a water main break I had to drive thru a large and deep puddle of water. My engine light came on the next day.
I checked the gas cap it was fine. The error message came out 1457.
I have only had this 2001 Honda Civic for 2 months.
Before I had this car I had a 1999 ford escort.
Last fall I had gone thru a deep puddle and had the check engine light come on the next day also. I replaced oxygen sensors twice, had a tune up and about everything you can think of. still the light would always come back on.
thats why I got rid of the car.
Now with my Civic I'm having similar problems.
These computers they have on our cars now days are some times hyper sensitive. Who knows. But try the least expensive options first.
dumping $700 bucks into a car and having the light come back on anyways
and the garage telling you there is nothing else they can do just isn't worth it. good luck.
deedeemac is offline   Reply With Quote
Old 07-21-2009   #8 (permalink)
Old 07-21-2009
CivicForums
Honda Civic
Paid Advertisement
Tags
01 , 02 , 200 , 2001 , 2002 , 2003 , 2005 , civic , code , codr , engine , error , fix , honda , p1457 , problme
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Who's had a bad transmission? *UPDATED*
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Your answer may be here! TSB / Honda Complaint Address / Etc...
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
ODB II Codes
DRL Problem
DIY: replacing power window motor assembly on my civic coupe
I Got 2 ECU Codes P1298 and P1519
check engine light
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
