Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-29-2004   #1 (permalink)
Civic2k1racer
Senior Member
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
knocking noise when i turn the steering wheel
every time i turn the steering wheel past the center(where i have the wheel straight to go straight) i hear a knocking noise as if somebody is knocking on a piece of wood. I hear it when i turn the wheel left or right, has anybody had this problem before? thanks oh and i have an x-brace which i took off becuae i thought it was the problem,but its still making the noise and i got a neuspeed strut bar To remove this ad, register today for free or log in if already registered!
Civic2k1racer is offline   Reply With Quote
Sponsored Links
Old 03-29-2004   #2 (permalink)
Prominencecivic
New Member
Prominencecivic is an unknown quantity at this point
I have no idea what it is but the same thing happens to my 04. It usually happens right when i turn the car on and turn out of the drive way. It also happens sometimes when iam parking, (the noise happens for me when the steering wheel is at center and as soon as i turn it left or right bam the knocking on the wood.)
Prominencecivic is offline   Reply With Quote
Old 03-30-2004   #3 (permalink)
jackscivic
Senior Member
jackscivic's Avatar
jackscivic will become famous soon enough
Send a message via AIM to jackscivic
its a long shot but try checking your power stearing pump. sometimes they do that. mine did.
jackscivic is offline   Reply With Quote
Old 05-17-2004   #4 (permalink)
RiCeMaN
New Member
RiCeMaN's Avatar
RiCeMaN is an unknown quantity at this point
I am also having the same problem. I just got these Neuspeed springs and when I turn my steering wheel, I hear the same noise. Let me know if you guys find a solution to this problem.
__________________
You can imitate, but never replicate.
RiCeMaN is offline   Reply With Quote
Old 05-18-2004   #5 (permalink)
elitecivicex01
Diamond Member
elitecivicex01's Avatar
elitecivicex01 will become famous soon enough elitecivicex01 will become famous soon enough
Send a message via AIM to elitecivicex01 Send a message via Yahoo to elitecivicex01
Quote:
same as you man...ive been told my many that it may jus be my Springs not sitting right and/or moving about in the boot when turning the wheel or making a turn. i have Neuspeed Race Springs (the yellow ones)
hope that comforts you in that you arent the only one
~Joey
__________________
http://www.civicforums.com/forums/signaturepics/sigpic11722_1.gif
HAVE: RR 2007 Honda Civic 4DR Si
SOLD: RR 2001 Honda Civic 2DR EX (5-speed)
Joey's MySpace
FA5 FTW!!!!!!!
...::HID-tested, Carbon Fiber approved::...
elitecivicex01 is offline   Reply With Quote
Old 05-18-2004   #6 (permalink)
RiCeMaN
New Member
RiCeMaN's Avatar
Guys, I was doing some research and I think I found the solution to those annoying spring noise. Check out this link. http://www.2k1civic.com/forums/showt...pring+neuspeed . Supposely, if you get coil wrap for your spring, it should fix the problem
__________________
Old 05-19-2004   #7 (permalink)
flotsamm
Ultimate Member
flotsamm's Avatar
flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold
Could be the above or that your struts werent indexed(lined up) correctly when reassembled. Read this post regarding indexing if you think this might be the problem..
http://www.7thgencivic.com/forums/sh...d.php?t=148207
flotsamm is offline   Reply With Quote
Old 05-19-2004   #8 (permalink)
HYPR DRV
Since 1977
HYPR DRV's Avatar
HYPR DRV will become famous soon enough
BINGO!! RiCeMaN is dead on. Same thing happened to me. If you have aftermarket springs (especially Neuspeeds) that is the problem. Wrap your dead coils, so they're not grinding when you turn.
HYPR DRV is offline   Reply With Quote
Old 05-19-2004   #9 (permalink)
RiCeMaN
New Member
RiCeMaN's Avatar
Cool
flotsamm, thanks for the link, but when I had my springs installed, I took it to RacingZone in Tampa,shop (well known for quality work) and the mechanic confirmed with me that the springs are installed properly. I honestly think that it's the neuspeed springs that is causing that "clanking" noise. I am going to get the coil wrap and have it installed. I'll let u guys know if that will get rid of that annoying noise.
__________________
Old 05-19-2004   #10 (permalink)
RiCeMaN
New Member
RiCeMaN's Avatar
Hypr Drv- one quick quick... How long does the coil wrap last? Once the plastic is wore out, will the noise come back? Let me know, thanks.....
__________________
Old 05-19-2004   #11 (permalink)
HYPR DRV
Since 1977
HYPR DRV's Avatar
That's a good question. Mine has been on for almost a year, I'd say, and no noises yet. So you'll be good for a while.
Old 05-20-2004   #12 (permalink)
sffree
Senior Member
sffree's Avatar
sffree is an unknown quantity at this point
I'd still double check that indexing issue.. I had my install done by pros but different car makes have different little quirks.. honda happens to have these stupid strut parts with arrows right on them that have to be lined up... I had to print out Flotssam's link (with the beautiful illustration) and they had to re-index cause they had no idea 'bou it...they didn't charge me cuz it was a stupid oversight on their part... but dat's how easy it is to miss...
sffree is offline   Reply With Quote
Old 05-20-2004   #13 (permalink)
RiCeMaN
New Member
RiCeMaN's Avatar
I called up Neuspeed tech support and described to them the noise. They told me that the only thing that could cause that noise is that the mechanic forgot to put back the strut bearing after he installed the springs. Let me know what you guys think about that. Thanks
__________________
Old 05-20-2004   #14 (permalink)
flotsamm
Ultimate Member
flotsamm's Avatar
The mechanic would have to be a complete moron if he forgot to install the bearing. The strut bearing is in between the top mount and upper perch and shouldnt have to be removed when replacing springs. If Neuspeed said that the noise can only come from the bearing missing, then they got alot to learn. Sounds like you got someone in tech support who doesnt know what to look for.
I would call up your shop and ask the mechanic who worked on your car if he indexed your struts correctly. Ask him how he did it. The correct way is to line up the two triangles on the top mount and upper perch with the hole on the lower perch like I mention above. Dont get me wrong, they could be indexed correctly and it could be something else still, but I'd give them a call anyway.
Old 05-22-2004   #15 (permalink)
RiCeMaN
New Member
RiCeMaN's Avatar
Guys, wish me luck, this Monday I am taking my car back to the mechanic to install those coil wrap for my springs. I hope this solves the problem. The noise is getting worst and this time it's making that noise without me turning my car. Driving over a little speed bump and the noise is there. Sounds like the noise is coming from the front right wheel. Who knows, I am just felt up with the "popping" noise. I am starting to regret lowering my car. It looks nice as hell, but is it worth the annoying sound.... If you guys have any other pointers, I am more than happy to share it with the mechanic.
Pretty much he (the mechanic) told me that this is the first time that he did a spring installation and the car is making this "popping" noise. This mechanic shop is not a ghetto out shop; it is actually a very nice shop and very well known for doing good work.
I'll let u guys know by Monday evening if the coil wrap works?!?!?!
__________________
Tags
knocking , noise , steering , turning , wheel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
