Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-24-2004   #16 (permalink)
Firetoe
New Member
Firetoe is an unknown quantity at this point
You've checked the power steering fluide level right. To remove this ad, register today for free or log in if already registered!
Firetoe is offline   Reply With Quote
Sponsored Links
Old 05-25-2004   #17 (permalink)
RiCeMaN
New Member
RiCeMaN's Avatar
RiCeMaN is an unknown quantity at this point
Here's the low down no my trip to the mechanic. The mechanic told me that he indexed my struts correctly the first time. This is a known fact and he is very aware of that. I had him installed the coil wrap on the spring (per Hyper drv) and the noise has gotten a better, but I still hear it. Now I am pretty much back to square one. Any other suggestions?
__________________
You can imitate, but never replicate.
RiCeMaN is offline   Reply With Quote
Old 05-25-2004   #18 (permalink)
HYPR DRV
Since 1977
HYPR DRV's Avatar
HYPR DRV will become famous soon enough
Quote:
Did they put the coil wrap around the dead coils? Just making sure, because it does no good to put it around the rest of the spring. Other than that, I have no idea what could be causing the noise. Sorry man.
HYPR DRV is offline   Reply With Quote
Old 05-25-2004   #19 (permalink)
RiCeMaN
New Member
RiCeMaN's Avatar
Yeah, they did......... hmmm the noise is still there and I am so annoyed..
__________________
Old 05-26-2004   #20 (permalink)
flotsamm
Ultimate Member
flotsamm's Avatar
flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold
So wait.. after he installed the coil wrap didnt he hear the knocking noise? He should of, and then put it back up on the rack to at least try to figure out WTF is up. I'd call him up and say that its still making the noise and you would like to know where its coming from. Also mention that it never made this noise before the install.
flotsamm is offline   Reply With Quote
Old 05-26-2004   #21 (permalink)
RiCeMaN
New Member
RiCeMaN's Avatar
The weird thing is after he installed the coil wrap, the noise was not there. I drive around the shop and it was quite. A day after, as I was pulling out of my drive way, I noticed the noise again. The more I drive my car, the worst the noise gets. I am soooo lost with this.... This is the third time that he has worked on my springs. We both dont know what else to do. He said that he could reinstall the old stock springs on. arghhhhh!!
__________________
Old 05-28-2004   #22 (permalink)
04em2
New Member
04em2 is an unknown quantity at this point
Send a message via AIM to 04em2
I had the same problem when i first put in my springs and it turned out that the nut on top of the strut was overtightened.....opps got a little impact happy....o well i believe that the proper torque is only like 17ft/lbs it got rid of my noise
04em2 is offline   Reply With Quote
Old 05-28-2004   #23 (permalink)
2002vtecsir
Member
2002vtecsir's Avatar
2002vtecsir is an unknown quantity at this point
i don't know mines wasn't my springs it only did it in second gear while making a right turn
2002vtecsir is offline   Reply With Quote
Old 05-28-2004   #24 (permalink)
civichxtreme
Senior Member
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
Send a message via AIM to civichxtreme
well i had the same problem but i learned it was my own fault i put the spring in backwards and not quite exactly where it should be for those of you with after market springs take your wheel off put the car upp on a jack and have someone turn the wheel and take a look
civichxtreme is offline   Reply With Quote
Old 05-30-2004   #25 (permalink)
RiCeMaN
New Member
RiCeMaN's Avatar
I am 100% sure that the springs are not on backwards.
__________________
Old 05-31-2004   #26 (permalink)
Khmi
New Member
Khmi is an unknown quantity at this point
I have the same problem on my car it is lowered on sportlines. I have noticed that when i jack up my car or change to stock tires the noise goes away for like half a day, then it come back. That might explain why you didnt hear the noise right away.
__________________
ALL SHOW NO GO
Khmi is offline   Reply With Quote
Old 05-31-2004   #27 (permalink)
02civic_rida
Ultimate Member
02civic_rida's Avatar
02civic_rida is a glorious beacon of light 02civic_rida is a glorious beacon of light 02civic_rida is a glorious beacon of light 02civic_rida is a glorious beacon of light 02civic_rida is a glorious beacon of light 02civic_rida is a glorious beacon of light
its ur CV JOints
Almost always when there is a nocking its the CV joints,
check the boots. good luck
__________________
I <3 my Honda
http://img.photobucket.com/albums/v7...ivic/ccsig.jpg
^^^EM2Crew REPPIN!!^^^
Quote:
Originally Posted by R1Style
I would punch a girl in the face before I would even think about punching/hitting my car.
02civic_rida is offline   Reply With Quote
Old 05-31-2004   #28 (permalink)
RiCeMaN
New Member
RiCeMaN's Avatar
It's not my cv joints. It's making a knocking noise, not a clicking noise that a bad cv joint would make.
Khmi- what are sportlines?
__________________
Old 06-01-2004   #29 (permalink)
chriscivic
Super Member
chriscivic is an unknown quantity at this point
its not the aftermarket springs. I had the problem with clicking and clanking on a completly stock civic. I took it under warrenty and had the whole front axels replaced
chriscivic is offline   Reply With Quote
Old 06-01-2004   #30 (permalink)
RiCeMaN
New Member
RiCeMaN's Avatar
Well, it was fine before I installed the aftermarket springs.
__________________
Tags
knocking , noise , steering , turning , wheel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
