Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-06-2003   #1 (permalink)
slowciv
Senior Member
slowciv is an unknown quantity at this point
Question tranny problem
while waiting at the light today i was in neutral, of course. as the light turned green i tried to put the car in first, it would go halfway, like something was stopping it. i tried several times and revved the motor but still nothing, i put it into second then back into first it finally went, but what is wrong? i never had this problem before. thanks To remove this ad, register today for free or log in if already registered!
slowciv is offline   Reply With Quote
Sponsored Links
Old 10-06-2003   #2 (permalink)
kjgracing
Hail to the king baby
kjgracing's Avatar
kjgracing will become famous soon enough kjgracing will become famous soon enough
I had that problem...It had to do with the shift linkage...my bolt came all the way
out and I had no gears to shift into ...ahhhH!!!!!!
All fixed now thoug and gears are tight when I shift
kjgracing is offline   Reply With Quote
Old 10-06-2003   #3 (permalink)
Entropy
Senior Member
Entropy's Avatar
Entropy is an unknown quantity at this point
Send a message via AIM to Entropy
does that have anything to do with the rubber bushings? this is an area I'm unfamiliar with, but I've ordered Kap Yoda's bushings and I'm hoping that will stop some shifting problems I've run in to.
Entropy is offline   Reply With Quote
Old 10-06-2003   #4 (permalink)
slowciv
Senior Member
where is the "linkage" at so i can check mine
Old 10-06-2003   #5 (permalink)
flotsamm
Ultimate Member
flotsamm's Avatar
flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold
That happened to me once also. I did the same thing as you did, put it in 2nd then back into 1st. I think it has to do with the synchro's not sync'ing up correctly. Kinda like how the owner's manual says that if your having difficulty going into reverse gear to put it in a different gear first to line up the synchro's. I believe our trannies dont have reverse synchro, but somehow it still helps the gears that do. Dunno.. guessing here.
flotsamm is offline   Reply With Quote
Old 10-06-2003   #6 (permalink)
tinman
tinman's Avatar
tinman is just really nice tinman is just really nice tinman is just really nice tinman is just really nice tinman is just really nice
This rarely happens, but can on any stick car. You were sitting in JUST the right spot were the gear teeth could not mesh. Happened to me on every car I drove at least once. Cure: Try 2nd and then first, this moves the gears just enough, or let off the brake to roll the car just slightly.
Yeah, it's a weird thing if it happens at a light. But it's not a tranny problem. Just dumb luck.
tinman is offline   Reply With Quote
Old 10-12-2003   #7 (permalink)
audioefx3
Senior Member
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
The reason to shift into a forward gear before reverse is the stop the gears from moving thus making it slide right into reverse smoothly.
audioefx3 is offline   Reply With Quote
Old 06-29-2004   #8 (permalink)
phil79
New Member
phil79 is an unknown quantity at this point
hey my car does it like a few times a day. but what i do is pull it to nuetral and then lift up on the clutch and push it back in. my friend says that it happens to all manual transmission is it true? or do i have a problem??!?
phil79 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
