Will Rubbing Alcohol Hurt Paint?
Rep Power: 0 Will Rubbing Alcohol Hurt Paint?
I used rubbing alcohol on the glass to remove dried up pine sap, but I am afraid to use it on the paint. Will it damage the paint? How about Goo Gone? If there is something better let me know.
Re: Will Rubbing Alcohol Hurt Paint?
We use rubbing alcohol to clean surfaces (including body paint) as prep for installing accessories that adhere with double sided tape.
It will strip wax but it doesn't seem to hurt the paint.
1 Post
Rep Power: 170 Re: Will Rubbing Alcohol Hurt Paint?
Isoprophyl alcohol is perfectly fine on both clear coat and gel coat. It is an excellent prep cleaner and evaporates quickly. We use it daily to neutralize the adhesive remover and to prep the surface for new decals.
But that said, it probably won't remove the sap. Use your goof off or goo gone or other adhesive remover then use the alcohol to clean it up.
09-27-2015 11:33 AM
