stupid question about detailing
Rep Power: 0 stupid question about detailing
hey when you guys talked about dressing the engine, is that something that you used to make the rubber or plastic parts shiny? is it like the armor all tire foam? because i tried using that and it didn't make the plastic/rubber parts shiny.
what brand would you recommend?
i'm really a noob when it comes to detailing
Rep Power: 252 Well if you want to do it the easy way you can go to the auto part store and buy a can of citrus cleaner that has a 2 stage tip that sprays cleaner and then detailer. If you want to do it right you need to cover your alternator and your intake if you have an aftermarket one. Then use a degreasing cleaner, i like simple green or Meguiars All Purpose Cleaner, you will probably need to wipe down certain parts. Then rinse, i suggest letting the engine run for about 15-20 minutes and dry as much as possible. Then i use Meguiars Hyper Dressing that provides that clean shine. Heres an example, not mine, of that method so you know what it can do.
Before
After
Before
After
I like Autoglym's engine cleaner. Spray then scrub with a soft brush. Then rinse well and dry as much of the compartment as you can(a shop vacum is fantastic for this if you use it as a blower) Then spray a vinyl dressing like clearkotes tire treatment over the rubber parts and let it sit for 10 minutes then buff off the excess.
Heres a picture of my Daughters Saab I did for her this summer.
Rep Power: 252 You can order it from Meguiars directly. Their shipping is REALLY fast. If you have an Orielly Auto Parts store down there they should be able to order it for you and have it in a day or 2. Try to go to one with a paint department, they can get it, or for that matter any auto parts store that sells paint can probably get it. Keep in mind that it only gives the shine, you also need a cleaner.
one of the laziest ways to shine up your hoses other plastic parts is spray on tire shine then wipe it off a few mins later... I've done that before a couple shows that I won my category for
Rep Power: 252 ^^ that works as long as you dont drive your car or mind the smell of burning tire shine. The Meguiars Hyper Dressing works the same way, only its meant for the engine.
Rep Power: 0 i have the cleaner, I use a degreaser, but somehow I dont know what to use to clean and make the black rubber parts shiny. I'll check out autozone/ orielly tomorrow.
are you serious about the smell of burning tires shine? so what product would you recommend to make it shiny that will not give the smell ?
Rep Power: 252 the hyper dressing wont give the smell. Its meant to be used in applications like this. its also much more durable and completely safe compared to spraying tire shine on the engine, thats just a bad idea.
Originally Posted by rckdrmr
btw... if you buy the hyper dressing it also works great as tire dressing. i dilute it 1:1 with excellent results!
i love hyper dressing....but as per meguiars it should be mixed anywhere from 4:1 to 10:1, have you tried silcone free dressing it comes rtu (ready to use) and leave a wonderful smell, i like it on interiors...303 is good as well
