Go Back   Honda Civic Forum > LOCAL/GEOGRAPHIC FORUMS > Canada East
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-13-2006   #1 (permalink)
AznSaint
Ultimate Member
AznSaint is an unknown quantity at this point
what's considered a good psi for summer tires? or any tires?
i've got the 205/50/16 falken's 451 tires... on the tires, it says 51psi max. and then there 's another note that says, DO NOT EXCEED 40psi on 16inch rims.
now, if i were to go ona race track.. i would probably have to set the psi at about 30 or 32 psi... b/c the heat will just rise dramatically....
but how about local driving/highway driving during the summer..... would 36psi be good enough? or would that be underinflated..>?
__________________
rice mobile
AznSaint is offline   Reply With Quote
Sponsored Links
Old 04-13-2006   #2 (permalink)
Blkcivic
Ultimate Member
Blkcivic's Avatar
30 psi
Blkcivic is offline   Reply With Quote
Old 04-13-2006   #3 (permalink)
AznSaint
Ultimate Member
Quote:
Originally Posted by Blkcivic
30 psi
for real? whenever my tires are at 30psi... it looks like it doesnt have enough air in 'em.........
__________________
rice mobile
Old 04-13-2006   #4 (permalink)
Transformer_Guy
Lost in the Matrix
Transformer_Guy's Avatar
Transformer_Guy is on a distinguished road
Ya, 30 is good
Transformer_Guy is offline   Reply With Quote
Old 04-13-2006   #5 (permalink)
DDragon7
Ultimate Member
DDragon7's Avatar
DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light
I'd probably go with 35psi.
__________________
I <3 My Honda
(Rep Me and I Rep Back)
2001 Civic SiG, 5spd, Eternal Blue, 126k km
www.ottawahondaclub.com - Admin
DDragon7 is offline   Reply With Quote
Old 04-13-2006   #6 (permalink)
AznSaint
Ultimate Member
okay, thanks
so 30psi to 35psi applies to all tires? summer or winter or stock?
i usually haev it around 38psi... like my stock or winter tires. i gues that's bad..........................
__________________
rice mobile
Old 04-14-2006   #7 (permalink)
phuviano
Slowest 7thgen in the GTA
phuviano's Avatar
phuviano has a spectacular aura about phuviano has a spectacular aura about
51 psi is the max pressure the tire can handle, not what you should set it at.
30 - 35 psi should be good. Set it at whatever you feel is more confortable to you. I would just stick with 30psi, which is the recommended psi rating from honda. I set my summer tires at 32 psi, and my winters at 28 psi.
btw, 38 psi is too much for the winter. You want to lower the psi in the winter, so you get better traction with your tires. There's no correct psi you must set it too, but stick with 30 psi to be on the safe side.
__________________
http://www3.sympatico.ca/phuvong/***********sig.jpg
phuviano is offline   Reply With Quote
Old 04-14-2006   #8 (permalink)
AznSaint
Ultimate Member
okay, thanks.
for some reason, ......... for example, my winter tires has 44psi max. and i usually set it at 38psi....... if any lower.. it would seem like it's too flat to drive on.... like the tire doesnt seem there's enough air on 'em.......
anything under 38psi looks under inflated to me...
but i guess now i know 30 to 35psi should be good...
__________________
rice mobile
Old 04-14-2006   #9 (permalink)
Nameless
TURTLEonK
Nameless's Avatar
Nameless is a jewel in the rough Nameless is a jewel in the rough Nameless is a jewel in the rough Nameless is a jewel in the rough
stay close to stock rating... any higher or lower you run the chance of wearing out your tires faster as well as loss of gas mileage... oh and of course higher risk of blowing ur tires
__________________
T-Compression -- Shinzo Werks -- NV -- Battle Endless -- www.intunedonline.com
CIVIC SEDAN Type-S
Nameless is offline   Reply With Quote
Old 04-14-2006   #10 (permalink)
FurBall
Diamond Member
FurBall's Avatar
FurBall is an unknown quantity at this point
Anything outside the range of 30-35 PSI for 'typical' summer/winter tires is way out of range.... I think really thin profile tires need to run in the 40 PSI ranges...
Anything below 30 is way underinflated, and you will cause excessive wear, and will also reduce structural integrity of the tire... the tire will end up 'rolling' onto itself alot...
I find 35psi for my summer OEM tires makes the driving very harsh...
I typically set it to 31-32PSI for both summer and winter tires. (185/65/R15 OEM FireStone for summer, Michelin Arctic Alpin for winter)
Remember also the PSI should be read with a better tire gauge than the one on the pump at the gas station, and must be read when cold (less than 5 mins low-impact driving)....
FurBall is offline   Reply With Quote
Old 04-15-2006   #11 (permalink)
cheukkin
Senior Member
cheukkin's Avatar
cheukkin is an unknown quantity at this point
whatever tires you are using, read the sticker along the edge of driving door, it's clearly indicated that what's the right psi for our car, no more no less, otherwise the tires might wearout fast or either harsh for driving...
cheukkin is offline   Reply With Quote
Old 04-15-2006   #12 (permalink)
AznSaint
Ultimate Member
Quote:
ya.. but i odnt think that sticker would apply to my thinner profile compared to stock
im riding on 205/50/16.
i think/thought we should have thin profile tires closer to 40psi also.. but the tire said do not exceed 40psi on 16inch rims...
so that's why i was curious about the right psi on tires.
__________________
rice mobile
Old 04-15-2006   #13 (permalink)
Axxe
Member
Axxe's Avatar
Axxe is an unknown quantity at this point
Tire pressure settings vary from tire to tire. Start from 30, and go from there. Some tires like higher pressure, some like lower. The key on the track, is to mark the sidewalls with chalk at 4 points on the tire, and to go out for a few hot laps, then come back in and check how much chalk has worn off, this way you can tell how much the tire is "rolling over." Keep adding air until the only the corners of the tires are rubbing chalk, not the sidewalls. Also, more air in the front causes understeer, and more in the back causes oversteer (very mildly, but uselful for dialing out that little bit of understeer).
Axxe is offline   Reply With Quote
Old 04-16-2006   #14 (permalink)
hdave
Super Member
hdave is an unknown quantity at this point
Send a message via MSN to hdave
wat psi for my 215/45/17?
__________________
2005 Civic SE
hdave is offline   Reply With Quote
Old 04-20-2006   #15 (permalink)
infinite
Super Member
infinite is an unknown quantity at this point
i run between 30-32 psi for my stock 15" rims in winter and 35-37 psi for my 18" rims in summer. never had a problem.
infinite is offline   Reply With Quote
Old 04-20-2006   #16 (permalink)
rjngo
Super Member
rjngo's Avatar
rjngo will become famous soon enough rjngo will become famous soon enough
i run 32psi both summer and winter
__________________
[SIGPIC][/SIGPIC]
rjngo is offline   Reply With Quote
Old 04-20-2006   #17 (permalink)
AznSaint
Ultimate Member
Quote:
what's max psi on your 18in tires?
__________________
rice mobile
Old 04-21-2006   #18 (permalink)
infinite
Super Member
max psi on the parada spec 2's is 40 if i remember correctly. i'll check later to make sure.
Old 04-25-2006   #19 (permalink)
Pluto
Senior Member
Pluto's Avatar
Pluto is an unknown quantity at this point
I have ran my 215/50/16 tires at 30psi for the past few summers, no issues here, they are wearing evenly.
__________________
'02 Black LX (CDN) Sedan, 5spd
Pluto is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Si Wheels/Tires...Need To Sell or Trade!!! All Offers Considered!!!!!!!!!! SaRno03Vic Honda Civic Parts for Sale 11 01-13-2005 06:16 PM
What PSI is best to have my tires inflated at? BIG Canada East 6 10-20-2003 12:32 AM
PSI Tires BatMan Mechanical Problems/Vehicle Issues and Fix-it Forum 1 08-10-2003 04:03 PM
what is the recommended psi for stock tires??? Element2k5 Wheels,Tires & Brakes 4 10-21-2002 12:20 AM
User Login
Our Partners
used new
Top 10 Threads
LONDON PEEPS: General Discussion (Part II)
MONTREAL area: General Discussion
NIAGARA region:General Discussion*Goto 1st post for Show info and Pic info!*
Wtf!!!
Race Queen thread *warning*
G2 road test...(need some advice)
Canada East Roll Call
OT: cutest girl in CAN EAST?? LOL
List Canadian Vendors Here Please!
Who wanted an LED center console?
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
