96 Honda Civic Help?
Old 04-15-2012
ELC
ELC's Avatar
ELC is an unknown quantity at this point
hello everyone,
Does anyone know of a good mechanic in the richmond va. area.
Need to have the steering column replaced and repaired, along with the key ignition.
Thanks in advance
Old 04-15-2012
Re: 96 Honda Civic Help?
What is wrong with the steering column? I have never seen problems there (well, at least not the same way GM columns had problems!).
The steering column lock (with key, cylinder, tumblers, and ignition switch) can be removed from the column and rebuilt or replaced.
The electrical section of the ignition (switch) is available separately from the column lock.
Old 04-15-2012
ELC
ELC's Avatar
All of the above.
All the components which you mention were taken apart, and not put back together. I have the mechanically skills to reuild it, but dont have the time.
jessicakaybby
04-20-2015 12:11 PM
Quick Reply: 96 Honda Civic Help?
