Go Back   Honda Civic Forum > OFF TOPIC > General Automotive Discussion
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-23-2005   #166 (permalink)
Freak
Senior Member
Freak's Avatar
Freak is an unknown quantity at this point
Send a message via AIM to Freak
Wow this thread is still goin!? To remove this ad, register today for free or log in if already registered!
__________________
Freak
Freak is offline   Reply With Quote
Sponsored Links
Old 06-21-2007   #167 (permalink)
blouisgod
Life Begins > 6800rpms
blouisgod's Avatar
blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold
Send a message via AIM to blouisgod
Re: Whats your biggest mistake you ever made while DIY?
this thread is classic
__________________
2008 ASM Si Sedan w/ Navi and Summer Tires
blouisgod is offline   Reply With Quote
Old 06-21-2007   #168 (permalink)
02civic21
Ricky Bobby style, IWGF
02civic21's Avatar
02civic21 is a jewel in the rough 02civic21 is a jewel in the rough 02civic21 is a jewel in the rough
Send a message via AIM to 02civic21
__________________
Quote:
Originally Posted by speedfoos View Post
Did someone come by and steal most of the vowels off your keyboard?!
Quote:
Originally Posted by filipinop1405 View Post
Get me a juice box!
1HGEM2
Quote:
You're trying to build a motor without being "so technical"? Get the hell out of here. What do you think it is, legos?
<!-- show-my-ip.com IP box code v.1.0 -->
<script language="javascript" src="http://show-my-ip.com/box/create"></script>
02civic21 is offline   Reply With Quote
Old 06-21-2007   #169 (permalink)
Kevbotron
I like my commute
Kevbotron's Avatar
Kevbotron is a glorious beacon of light Kevbotron is a glorious beacon of light Kevbotron is a glorious beacon of light Kevbotron is a glorious beacon of light Kevbotron is a glorious beacon of light Kevbotron is a glorious beacon of light Kevbotron is a glorious beacon of light
Send a message via AIM to Kevbotron
I didn't really have the best tools to install my intake, so I basically broke all off the mounting points off my air boxes oh and I sprayed my rotors a little bit when painting my calipers then I got new ones
__________________
Kevbotron is offline   Reply With Quote
Old 06-21-2007   #170 (permalink)
drunkenmagnum
drunkenmagnum's Avatar
drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light drunkenmagnum is a glorious beacon of light
Send a message via AIM to drunkenmagnum
fucked up the v-tec sylonoid reinstalling the head that i took off in my garage. also snapped a oil line that was loose off with the fitting still stuck in the block- big mess. stripped a wheel studd b4....i got more but these r probably the biggest
__________________
196 hp
194 fpt @ 10psi - Before the rebuild
"My d!ck feels like corn"-Dane Cook
R.I.P 7thgencivic.com
Type-S Fuel Injectors for sale.
WTB: 02-04 ep3 (si) rear brake assembly
T.E.A.R.S crew member #1
Car for Sale
drunkenmagnum is offline   Reply With Quote
Old 06-21-2007   #171 (permalink)
bakertime
Senior Member
bakertime's Avatar
bakertime is a jewel in the rough bakertime is a jewel in the rough bakertime is a jewel in the rough
I drilled a hole in my buddy's brake booster in his explorer while running a power line for an amp.
Oops.
__________________
1997 Integra, Built N/A B18C1, 11.6:1 CR, tuned on a Hondata S200/ P28
2001 Civic EX, Ksports, Magnaflow Exh., SRI, SS - SOLD
bakertime is offline   Reply With Quote
Old 06-21-2007   #172 (permalink)
chopper202
Member
chopper202 is an unknown quantity at this point
I was usning my arc welder to weld my muffler to the little bolt on bit and I had the ground wire connected to that... well I obviousley didnt clamp it on to well it came off bout half way round the process and I didnt see it fly off through the tinted helmet well the welder and muffler sucked together and I welded my muffler to my welder and pretty much went straight through the the two layers together... I eneded up just taking it to a welding shop to fix my biggest and most expensive diy mistake..
__________________
If you drive fast enough you'll be past the accident before it happens* (*conditions apply)
chopper202 is offline   Reply With Quote
Old 06-21-2007   #173 (permalink)
sl33pyriceboi
Ultimate Member
sl33pyriceboi's Avatar
sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold
Send a message via AIM to sl33pyriceboi
it was a retrofit. i finished and sealed everything and relized i forgot to take off the serran wrap that i covered teh highbeam and projector...
i had to spend the extra time to take it aprt clean teh sliicone (a bitch may i add) and reseal it.
__________________
7thGen.MT.C.
Quote:
Originally Posted by gearbox View Post
alot of people just talk to say something. most of the time they have no idea wtf is going on lol
Quote:
Originally Posted by manahoonie View Post
lol. well we got newbs to use the SEARCH button.... NOW the next step is to look at the date
Step 1) SEARCH
Step 2) DATE CHECK
sl33pyriceboi is offline   Reply With Quote
Old 06-22-2007   #174 (permalink)
colourwolf
Senior Member
colourwolf's Avatar
colourwolf will become famous soon enough
i scratch my car when i was waxing it.
and
Happy birthday to this thread...it is 4 years old..lol
colourwolf is offline   Reply With Quote
Old 11-26-2007   #175 (permalink)
uv_blue
Member
uv_blue is an unknown quantity at this point
so i knew this kid for about 10 years n yes i will admit he was a ricer one day he shows me this ridiculous dual deck wing that he wants to put on the back of his hyundai accent... insert laughter here... so anyway he wants me to drill the holes since he thinks i know about these things.. his mistake i know about fixing cars not installing ricer add ons ... anyway so i drilled the holes got everything aligned only to find that his bolts werent long enuf to go thru the framework on the back side they only went thru the actual skin... so i had to drill thru the framework with a 3/4 inch drill bit so that he could bolt directly to the skin n use washers well i get to the last one and by this time everyone in our school shop is watchin waitin for me to fuck up so i get thru the framework and the trigger "sticks" needless to say i drilled a 3/4 inch hole all the way thru his trunk lid he then bolted everything up and siliconed the hole while i recieved a wonderous applause
uv_blue is offline   Reply With Quote
Old 11-27-2007   #176 (permalink)
colourwolf
Senior Member
colourwolf's Avatar
Quote:
Originally Posted by zen_master View Post
when i was unscrewing the screw on the OEM shifter....i broke it.....1/2 of it still remains on the chassis....
that was........crazy...
lol....me 2...and it is still in there....how did u get it out
Old 11-27-2007   #177 (permalink)
RedHonda00
Member
RedHonda00's Avatar
RedHonda00 is an unknown quantity at this point
fixing the wiring to my cigarette lighter and the wires kept touching and kept blowing a fuse. was very frustrating & went threw alot of fuses that day
__________________
RedHonda00 is offline   Reply With Quote
Old 09-24-2008   #178 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all
Quote:
Quote:
W.......T........F? Does anyone else understand anything from these 2 posts? There's no punctuation at all.
__________________
7th Generation Member Against Street Racing Number 43
www.em2ab.com
Fully integrated carputer with W-Fi, GPS, 2000 songs/music videos, and weather
7 inch Xenarc 700TSV VGA in dash touchscreen
Compustar 2 way paging alarm/starter system
35% tint excluding windshield
D.I.Y. Blacked Out Headlights
D.I.Y. Debadge
D.I.Y. Remote Trunk Release
D.I.Y. Trunk Air Shocks (Scouting Parts)
Air Ride Suspension Setup (Awaiting Parts)
DeX is offline   Reply With Quote
Old 09-24-2008   #179 (permalink)
sl33pyriceboi
Ultimate Member
^does anyone even read them???
hahah i looked at them n was like.....aww sh!t, too long.
im sure most ppl on here dont read anything more than 3 lines...
__________________
7thGen.MT.C.
Step 1) SEARCH
Step 2) DATE CHECK
Old 09-24-2008   #180 (permalink)
Tragedy
skate or die
Tragedy's Avatar
Tragedy is a name known to all Tragedy is a name known to all Tragedy is a name known to all Tragedy is a name known to all Tragedy is a name known to all Tragedy is a name known to all Tragedy is a name known to all Tragedy is a name known to all
One time I put the car up on jack stands, installed a new exhaust part, then realized I installed a new gasket without taking the old one out. So I had to take it off, and re do it all.
__________________
"Unless someone like you cares a whole lot, nothing is going to get better. It's not."
-Dr. Seuss, the lorax
http://www.civicforums.com/forums/signaturepics/sigpic35349_1.gif
Tragedy is offline   Reply With Quote
Tags
8th , biggest , city , civic , control , cruise , diy , em2 , honda , instal , lights , made , mistake , put , speedo , whats , wheel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Take Pics of Local Ricers
Manual vs Auto
Two New Spyshots of the 2009 Acura TL/TSX Mule
Official: 8th gen civic thread (UPDATES on first post)
All of 7thGenCivic.com ROLL CALL !!!!!! HOW DEEP ARE WE ???
Official 2006 Honda Civic Hatchback
Find the 8th Gen Civic
your top speed
So what IS an Acura EL anyway?
Site Supporters
aluminum radiator
Honda car spoilers
