General Automotive DiscussionGeneral automotive discussion and chat. Honda, Toyota, Chevrolet, Ford. It doesn't matter, just talk about it here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Umm, if you guys want a good description of how the VTEC system works, check out http://www.howstuffworks.com/question229.htm. There's some cool animated pics too! It's a good read.....you'll appreciate the good design that went into producing our engines .
If you ask me VTEC doesn't rule anything, its the second cam. Almost all cars nowadays have multiple cams. Some trucks have quad-cams, becuase they're 'V' engines and two per side. As apposed to our inline engines which only have two. If you look at a dyno chart, you can't see when the VTEC kicks in, all you see is that second cam kicking in.
And yes, torque does rule. Try uphill endurance racing with a s2000 vs a supra, and see who wins. Torque is what is going to get you up that hill fast, not your HP.
Quote
[hr]if u had no torque u'd have no horsepower. - go back to school.[hr]
Dude, I didn't literally mean 0 torque. I meant it doens't need 300lb/ft of it. Figure of speech. Damn you people can be hostile.
By the way... the good old "race a honda up a hill" comment? hehe. time for school.
This was an actual experiment done for a physics project. (the numbers in here aren't exact, and i'm not getting into exact equations)
The amount of force and S2000 produces, when calculated with weight (disregarding drag coefficient), gives it a 1/2 gear acceleration rate of an average of 5.5ft/second*squared. A stick shift LT1 camaro gets about an average of 5.45ft/second*squared. So on a flat surface, from a 20mph roll, both cars produce the same amount of forward momentum, and accelerate at roughly the same rate, varying with the powerband. With weight factored in, both cars produce an equal amount of forward force.
Now, go uphill.
This means both cars must move forward as well as up. The amount of force required to move up is determined by rate of ascent, slope, and the amount of weight being moved.
Since both cars are going up the same hill, the rate of ascent and slope are equal. However, the camaro weighs more.
What this means is that the camaro requires more force taken away from forward momentum to be applied toward upward momentum. What does this all mean? The S2000 now has a greater amount of forward momentum left after removing the amount of force required to move up as well. So the theory behind this was that even though the camaro produced 300lb/ft or so of torque, and the S2000 only 150lb/ft or so, the S2000 would still go uphill faster. Again, this is because the camaro has more weight, and therfore more force required to move up.
We then put this theory to the test in real life. 10 runs were made on a flat surface from 20 to 60mph. All 10 runs neither car really pulled. Now uphill. again 10 runs. EVERY TIME the S2000 slowly pulled on the LT1 camaro.
The amount of force produced by a car whether going uphill or on a level surface is the same. Therefore when two cars producing an equal amount of force and forward rate of acceleration go uphill. The lighter car will accelerate faster since it has less weight to pull up as well as forward.
Want to try this at home? Run up a hill as fast as you can and time yourself. Now catch your breath and get your strength back... go downhill and pick up something heavy... say 20lbs or so. Now run uphill again and time yourself. I gaurantee you it will take longer.
i have a EX (with VTEC) and i drove my friends LX (Non-VTEC) and i can tell you there deffinetly is a difference. My car when it gets to 5 grand goes a whole lot faster than his to redline. Also ask him (Panda) who's cars faster[IMG]i/expressions/demon.gif[/IMG]
That would be the horsepower differnce not te vtec and the torque peaks higher up but there isnt more torque.
That would be the horsepower differnce not te vtec and the torque peaks higher up but there isnt more torque just hp.
