Dayco or Gates timing belt kits?
Old 03-24-2011
xgtcivicturbo's Avatar
xgtcivicturbo is an unknown quantity at this point
Question Dayco or Gates timing belt kits?
I need some inputs or review on which is a better manufacture on Dayco or Gates that makes timing belt kits for the 7th Gen Civic that last a while base on mileage wise and quality? Which should i get Dayco or Gates the whole timing kits? Opinion needed, Thanks in advance!
Old 03-24-2011
Trance Addict
MelJ's Avatar
Re: Dayco or Gates timing belt kits?
I've heard of them, but I haven't heard anything about their products. Personally, I'd just go with the Honda OEM kit. At least you know you'll be getting good stuff.
Old 03-24-2011
yeah i never saw a problem with dayco belts we sold, but i would still stick with oem because those are proven to last 100k miles already.
Old 03-24-2011
Live for the Twisties
MindBomber's Avatar
OEM, the kit itself isn't that expensive and they're very important components that last a long time.
Old 03-25-2011
sl33pyriceboi's Avatar
There aRe two basic companies that make belts in the world, gates and someone else. So you are good with either
Old 03-25-2011
2010 Civic Si
K20Z3's Avatar
K20Z3 is on a distinguished road
Yeah theres no reason to really look anywhere else for a timing belt kit. Its something you'll never even think about unless something goes horribly wrong. Just put in the OEM kit and forget about it.
Old 03-30-2011
JonDorian JD's Avatar
JonDorian JD is an unknown quantity at this point
Last July I installed a Dayco Timing Belt/Water Pump kit sold @ AAP - that was 12,000 miles ago haven't had any trouble yet. I wanted to do it quick, AAP had the whole kit with tensioner, it was just easy and sales guy, also a friend of mine, said they've sold them for years with no complaints.
Honda also definitely provides a quality belt (can't say so much for their transmissions) - the old belt had 130K and was still in great shape for a belt that old. You could see a really little bit of cracking in the rubber when you bent it but I'd be willing to bet if I had left it on the car it would have lasted alot longer. It said Honda on it - but it also said it was manufactured by Gates - so you're not getting any special Japanese recipe as far as I can tell and you can buy Gates belts aftermarket and avoid $tealership prices if you wanted to go that route -either way I'd highly recommend finding a nice kit that includes everything to make your life easy. Also - you'll need a gasket here and there not included in the kit - like for the valve cover.
Have fun with that crankshaft bolt - I had to burrow a 3/4-inch impact wrench and heat it with propane (avoid this propane part if at all possible)
mattdoc
03-14-2017 12:10 PM
Supramk3
05-11-2015 07:55 PM
MN-02-CivicEx
28
05-02-2015 09:11 PM
dano2005
04-14-2015 01:58 AM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: Dayco or Gates timing belt kits?
