replace tie rod end or others parts i might need?
Old 01-07-2011
xgtcivicturbo's Avatar
xgtcivicturbo is an unknown quantity at this point
Question replace tie rod end or others parts i might need?
I drove 7th gen civic in the snow recently and when i turn at the intersection, i guess the road was frozen so my whole vehicle slide and hit passenger side where the wheel is at, the wheel hit the sidewalk and the front bumper. Now that i notice that my steering wheel is leaning toward right side of the passenger side, it not straight like it was before, i notice i need alignment to be done, Do you guys think i need tie rod end to be replace or any others mechanism need to be replace recomended? Much helps need and be appreciated. If i need to replace such and such how much will it cost the parts and the labor wise? Thanks in advance!
Old 01-07-2011
Trance Addict
MelJ's Avatar
Re: replace tie rod end or others parts i might need?
TREs are a pretty easy fix for a DIYer. All you really need are some jack stands, a jack, some wrenches, sockets, a ratchet, and a pitman arm puller. You'll have to get it aligned once you're done, so you're covered there. Depending on how bad the damage is, I'd get everything checked out just in case. If you get tie rod ends, get the Moog ones. They're serviceable and, iirc, come with a lifetime warranty. Advance auto sells them. Don't know if Auto Zone or other stores sell them. They cost me about 50 or 60 bucks I think.
Old 01-07-2011
lazlong's Avatar
Go down to NTB and buy the $59.99 1-year unlimited alignment (prices may vary. lol). If they can't get it in alignment they'll tell ya what's broken/bent. Then you can fix it and bring it back for an alignment for the next year and don't have to pay anymore money. This has saved me a bunch of money over the years. The potholes around here are so bad I have to take it in for an alignment 3 or 4 times a year.
Old 01-07-2011
Trance Addict
MelJ's Avatar
Damn. After hearing that lazlong, I won't complain about NYs roads. Lol.
Old 03-28-2011
bigheadmark's Avatar
bigheadmark is an unknown quantity at this point
re: Moog. other than having a lifetime warranty, and being serviceable (greasable?) are they better quality than OEM?
Old 03-28-2011
lazlong's Avatar
^^ Yes. They are more robust. A side-by-side comparison will instantly show the difference.
Old 03-28-2011
Trance Addict
MelJ's Avatar
Definitely. Their sway bar links are also beefier. Plus, the Moog TREs, should have a grease fitting for service.
Old 03-28-2011
MELJ, would changing the sway bar link to a moog make a difference in performance? if so, how?
Old 03-28-2011
Trance Addict
MelJ's Avatar
My car didn't really "wobble" like it did when I took turns like it did when mine broke. Plus, the car was quiet again because it wasn't knocking against the car anymore. You might notice a slight increase in handling, but it's nothing to write home about. I'd still say if you haven't changed them, it wouldn't hurt anything I guess.
Old 03-28-2011
it will not give any better performance than the stock links. however the moog parts are much stronger and less prone to breaking.
Old 03-30-2011
qijian's Avatar
moog is just better overall. But there's probably bigger problems if the car doesn't drive straight after the accident.
bsmiley
04-27-2015 01:27 PM
El_Spic
04-23-2015 03:14 PM
thesushiboy
04-12-2015 02:54 AM
my2k1vic
11-29-2001 10:29 PM
CivicHX01
11-29-2001 03:48 PM
Quick Reply: replace tie rod end or others parts i might need?
