Go Back   Honda Civic Forum > OFF TOPIC > General Automotive Discussion
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-16-2009   #1 (permalink)
diahni
New Member
diahni is an unknown quantity at this point
Thumbs up I reset my SRS light - now what?
Greetings civicforum members:
I am just a "parts changing monkey," and no mechanic. Well, my airbag light was on and I flunked the inspection. I used the info on this forum to reset the light.
Thanks, guys! It was easy.
So it's off now, but I have an important safety question: By resetting the light, I'm assuming that if there were a problem with the air bags, the light would go back on. Is this correct? I recently had work done on my car from a slight front crash, and I think the mechanic forgot to reset the airbag switch, which is why it was on. Please let me know! Btw, I have a 2003 civic EX. It rocks. I want my inspection sticker ASAP, but I also don't want to be driving around with airbags that don't deploy. Thanks so much. Wow, is this forum ever valuable. The Honda place would have probably charged me a hundred bucks to do this.
diahni is offline   Reply With Quote
Sponsored Links
Old 10-16-2009   #2 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Re: I reset my SRS light - now what?
The system does a check each time you start the car. As long as the light goes off the system should be o.k.
CraigW is offline   Reply With Quote
Old 10-16-2009   #3 (permalink)
PaCiFiKbAllA
Super Member
PaCiFiKbAllA's Avatar
PaCiFiKbAllA should not be questioned PaCiFiKbAllA should not be questioned PaCiFiKbAllA should not be questioned PaCiFiKbAllA should not be questioned PaCiFiKbAllA should not be questioned PaCiFiKbAllA should not be questioned PaCiFiKbAllA should not be questioned PaCiFiKbAllA should not be questioned PaCiFiKbAllA should not be questioned PaCiFiKbAllA should not be questioned PaCiFiKbAllA should not be questioned
Send a message via AIM to PaCiFiKbAllA
take it to the dealer...they need to replace the SRS module if they haven't done so already...its part of a recall. and on the SRS light DIY.
__________________
SSM Never Looked So Good!
PaCiFiKbAllA is offline   Reply With Quote
Old 3 Weeks Ago   #4 (permalink)
RXD
New Member
RXD is an unknown quantity at this point
there is a yellow plug under the dash that has two wires going into it. the plug is plugged into an empty socket by the fuse pannel. take that plug out, place a jumper wire into the two holes connecting the two. turn the ignition key on.(lights on do not start) the srs light will go off, within 4 seconds, unplug one side of the jumper wire, when the srs light comes back on plug the jumper back in,(within 4 seconds) the light will blink twice and go out. unplug the jumper and turn the ignition key off. wait 15 secongs, then start your car. the memory will be reset. replace the plug and you're set. i am an ase certified mechanic and can't believe that we have a forum that noone will share this information on. what is this place for anyway?. sorry you had to go through this. but i feel that " Buy a scan tool " is the most stupidest responce. if i wanted to spend $900.00 on a tool, i'd pay the $200.00 to have the dealer do it. my goodness.
__________________
Take a drive in your Civic Reborn through Luray VA accommodations,for something completely unique.
RXD is offline   Reply With Quote
Tags
01 , 07 , 2001 , 2002 , 2004 , 2007 , accident , air , airbag , bag , civic , crv , honda , light , reset , srs
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Take Pics of Local Ricers
Manual vs Auto
Two New Spyshots of the 2009 Acura TL/TSX Mule
Official: 8th gen civic thread (UPDATES on first post)
All of 7thGenCivic.com ROLL CALL !!!!!! HOW DEEP ARE WE ???
Official 2006 Honda Civic Hatchback
Find the 8th Gen Civic
Whats your biggest mistake you ever made while DIY?
your top speed
So what IS an Acura EL anyway?
Site Supporters
aluminum radiator
Honda car spoilers
